Loading...
Pages: 1 [2]   Go Down
Author Topic: Burning Code in a DIY Arduino  (Read 641 times)
Offline Offline
Full Member
View Profile
True, but then you have to make sure you don't have anything connected to Tx/Rx for best results.
Quote
So, is that means it is better not to connect any input/output device at the MOSI, MISO and SCK pins ?
It depends on the device a bit. SPI devices are designed for this sort of thing, you just don't activate them through their slave select pin.
So do this means that I cant connect anything to this 2 pins ? Or it is not adisable to connect anything here?
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
It depends what you are doing. On the Uno the Tx/Rx pins are connected to the USB chip and have pull-ups on them, making them not particularly useful as input pins.
Also if you put a load on them you may not be able to upload a new sketch until you disconnect it. This may or may not bother you.
Logged
Offline Offline
Full Member
View Profile
You mention it has pull ups. So meaning that I can put a button there as an input ?
Correct me if I am wrong smiley
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
A button to ground should work. Are these just a lot of hypothetical questions or do we have a project here?
Logged
Offline Offline
Full Member
View Profile
Yea, a button to GND and to TX/RX pins should just make it a pull up button right ? So, I think I no need this below code to activate the pull up ?
Code:
digitalWrite(0/1, HIGH)
I am just asking for my own notes so I will becareful when in my project smiley-grin
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Let's not get bogged down here. Possibly that line could be omitted, but if you make a stand-alone version (without the USB chip) then you would need it.
Logged
Offline Offline
Full Member
View Profile
Thanks alot ! smiley-grin
Logged
Offline Offline
Newbie
View Profile
Yes this only makes sense when using USBtinyISP.
I need to learn more on SPI... Actually I have difficulty making a distinction from
UART - This is a Tx -> Rx & Rx -> Tx single device connection right?
I2C - As for as I know, this is a 2 wire protocol which can accept a maximum of 255 channels and any device connected to the same channel gets the message sent
SPI - As for SPI, I will try to see the link but so far I have no clue ! smiley
Cheers
Logged
Offline Offline
Newbie
View Profile
I am too asking questions to learn. I do have a small project (a 16 relay board with 2 pots connected to ADC and 4 buttons) and am trying to design the board from scratch without the usb connection and without the usb-to-serial-ftd-chip.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
No. Better read this:
http://www.gammon.com.au/i2c
http://www.gammon.com.au/spi
http://www.gammon.com.au/forum/?id=10918
Logged
United Kingdom
Online Online
Faraday Member
View Profile
WWW
You can safely use them for push buttons and similar inputs that don't mind being driven by the programmer, and for non-critical outputs such as the Data and RS inputs of a text-mode LCD display (the LCD ignores what you put on Data and RS until you pulse EN).
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Pages: 1 [2]   Go Up
Print
Jump to:
