Loading...
Pages: 1 2 [3] 4 5   Go Down
Author Topic: Small power source for one century  (Read 2281 times)
Offline Offline
God Member
View Profile
how about this for idea...
what left for 100 years would create a battery? ...
Logged
unprobable country named Belgium
Offline Offline
Full Member
Ga bu zo
View Profile
The time capsule is a metal box and it wil contain 100 objects. It will probably be stored in an attic. The circuit to be triggered after 100 years will be an audio circuit (maybe with a surface transducer sticked to the metal of the case).
Therefore I don't see a possibility with solar power.
Maybe it will be easier to use the services of a bailiff.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Set up a temple around it with a bunch of monks to care for it and organize a suitable ceremony when it opens.
Logged
Grand Blanc, MI, USA
Offline Offline
Edison Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
No doubt the power source is the stickiest problem here, but I'd also design some redundancy into the electronics. Source all parts based on reliability. That probably puts the flaps down on those cheap capacitors from eBay smiley-roll
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Offline Offline
Edison Member
View Profile
WWW
Perhaps some sort of electromagnetic energy harvesting approach?  Assuming an urban setting, the energy available might even increase over time.  And if there is none in 100 years, it's probably because there's no one left to open the time capsule anyway. smiley-eek
Logged
Offline Offline
Newbie
View Profile
A fuel cell could periodically charge a rechargeable battery or supercapacitor , therfore neutralising each other's shortcomings. I have a feeling you will end up needing a lot of power. Suppose the rechargeble could stay charged for 10 years, then the fuel cell should be able to work 11 times. This seems doable to me. Or you could use a wet battery and just replace the electrolyte with fresh one periodically.
Maybe temperature gradient exploitation using peltier devices?
I was going to suggest a radioisotope generator, but I doubt you can get one.
Or , someone mentioned a turtle. Don't they live 100 years? How much food could a turtle possibly eat in 100 years?
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
You could rig up a little generator, based on a DC or stepper motor.  "Turn crank" or "pull string" to activate...
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Over 100 years you could probably harvest the EMP from lightning strikes and the kinetic energy from tectonic movement/earthquakes.
Logged
Anaheim CA.
Offline Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
View Profile
If there is no one to open the box in a hundred years, Who cares... But a water activated battery and some stored water and some instructions to "Pour Water Here to Activate" should work... All sealed in an inert gas? Nitrogen?, Neon, Argon to avoid corrosion. If the water contained a mild acid, Zinc and copper would serve well and I'm sure that there are better methods than what 2 minutes consideration gave me.
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Valencia, Spain
Offline Offline
Edison Member
View Profile
Assuming somebody is there to see what's in the box when it opens, why not put in a hand crank? They can use it to open the box manually.
The curiosity of passers-by will make sure the crank is turned once in a while. You can use that energy to charge a capacitor to run the Arduino for a while until the next person turns it.
The principle is basically the same as those water pumps that are connected to a children's playground. The infinite energy of children makes sure that no adult ever has to pump water manually.
« Last Edit: January 29, 2013, 02:11:25 pm by fungus » Logged
Offline Offline
Full Member
View Profile
Going out on a limb here, but if it's in the loft of a house, why not tap into the house wiring? I've done some math, I think it could work.
Logged
For whom does the clock pulse? It pulses for you!
Charlotte, NC
Offline Offline
Newbie
View Profile
Most terrestrial batteries suffer from degradation from not being used as well as wear from use.
One of the longest known standalone power supplies would be the Radioisotope Thermoelectric Generators (RTGs) used in the Voyager spacecraft. Thirty-four years after launch, they are providing 57% of their rated output. Based on that, they will most not likely reach one century of operation.
There is the possibility of coupling a mechanical drive system to some form of generation. In the case of a time capsule, if it was suitably located hydroelectric generation would be a possibility. Depending on the environment for storage, a thermocouple might be usable to supplement the primary power.
In order to reach the goal of a century, a mechanical watch mechanism might be a better bet for the timing - if you can find a power source with sufficient shelf life to wait to be activated.
No matter which method you use to power it, you will have to take a note from spacecraft design, and make the entire system redundant, such that a failure of 50% of the components would still leave it in a usable state.
Logged
Croatia
Offline Offline
Full Member
View Profile
You've actually done math on this? On which part exactly? Does it include the centennial lifespan of 5V transformer?
Logged
Anchorage, AK
Offline Offline
Sr. Member
View Profile
Have a little crank on the outside of the time capsule that turns a generator and charges a battery. Put a sign that reads "Please turn crank".
FTFY:  "Please DO NOT turn crank."
That should guarantee it gets turned once a week or so.
Seriously, though.  It's going in an attic?  Has anyone owned an attic for 100 years?  Maybe I'm just American, but after 60 years or so, houses tend to get remodeled and/or demolished.
Logged
Offline Offline
Full Member
View Profile
Seriously, we have cowsheds older than America smiley-wink The pier I walked on this afternoon was built in 1867, it looks pretty much the same as when it was built. And the pub I visited after has been a pub since late 1700's, it was however  remodelled then as it was formally a place where cider was made. Not everything is pulled down every 60 years. So I reckon, a European loft has a good chance of surviving another 100 years (we gotta keep our chickens somewhere!)
Logged
Pages: 1 2 [3] 4 5   Go Up
Print
Jump to:
