Loading...
Pages: [1] 2   Go Down
Author Topic: Arduino not responding via serial communication  (Read 314 times)
India
Offline Offline
Newbie
im a newbiee..... but has a beleif and trust to find something new....
View Profile
Hi all>>>> Some people may know about my project work on quadrotor with gsm control....
Any here is a small review >>
My project is about a quadrotor which should be controlled by gsm sms..
so in order to make this possible i wrote some of the few stuff except the GSM section ...
Here is the problem>>
When i upload this code my arduino doesnot show any response in either serial communication nor in the actual>>>
so i tried of uploading a simple code that is character analysis as in example section which worked fine in serial communication>>
what is the problem ??
here is the code>>
Code:
#include <Servo.h>
#include <L3G4200D.h>
#include <PID_v1.h>
L3G4200D gyro;
 double Measuredx, Measuredy, Measuredz, Measureda, Outputx, Outputy, Outputz, Outputa, Setpointx, Setpointy, Setpointz, Setpointa;
PID X(&Measuredx, &Outputx, &Setpointx, 1.8, 0.42, 0.5, DIRECT);
PID Y(&Measuredy, &Outputy, &Setpointy, 1.8, 0.42, 0.5, DIRECT);
PID Z(&Measuredz, &Outputz, &Setpointz, 3.8, 1.3, 0.15, DIRECT);
PID A(&Measureda, &Outputa, &Setpointa, 3.8, 1.3, 0.15, DIRECT);
Servo FM;
Servo BM;
Servo LM;
Servo RM;
    /*      *(FM)
   (RM)* -- + -- * (LM)
            *(BM)
#include <Wire.h>
#define MIN_THROTTLE 1060
#define MAX_THROTTLE 1860
#define AX A0
#define AY A1
#define AZ A2
#define gX (int)gyro.g.x
#define gY (int)gyro.g.y
#define gZ (int)gyro.g.z
#define trig_pin 12
#define echo_pin 13
int THROTTLE;
float ax,ay,az;
double zeroValue[6] = { 0 }; // gyroX, gyroY, gyroZ, accX, accY, accZ
/* All the angles start at 180 degrees */
double gyroXangle = 180;
double gyroYangle = 180;
double gyroZangle = 180;
// Complimentary filter
double compAngleX = 180;
double compAngleY = 180;
// Used for timing
unsigned long timer;
void measure_height(){
  int duration;
  digitalWrite(trig_pin, HIGH);
  delayMicroseconds(1000);
  digitalWrite(trig_pin, LOW);
  duration = pulseIn(echo_pin, HIGH);
  Measureda = (duration/2) / 29.1;
void esc_calib(){
 Serial.println("ESC Calibration");
    Serial.println("Front MOTOR");
    FRONT(MIN_THROTTLE);
    Serial.println("Back MOTOR");
    BACK(MIN_THROTTLE);
    Serial.println("Left MOTOR");
    LEFT(MIN_THROTTLE);
    Serial.println("Right MOTOR");
    RIGHT(MIN_THROTTLE);
 Serial.println("Calibration Success");
  void FRONT(int x){
    FM.writeMicroseconds(x);
  void BACK(int x){
    BM.writeMicroseconds(x);
  void LEFT(int x){
    LM.writeMicroseconds(x);
  void RIGHT(int x){
    RM.writeMicroseconds(x);
  void attach_MOTORS(int i, int j, int k, int l){
    delay(100);
    FM.attach(i);
    delay(100);
    BM.attach(j);
    delay(100);
    LM.attach(k);
    delay(100);
    RM.attach(l);
    delay(100);
 void read_ACC(){
  ax=analogRead(A0);
   ay=analogRead(A1);
   az=analogRead(A2);
 void calibSensor(){
    for (uint8_t i = 0; i < 100; i++) { // Take the average of 100 readings
    gyro.read();
    zeroValue[0] += gX;
    zeroValue[1] += gY;
    zeroValue[2] += gZ;
    read_ACC();
    zeroValue[3] += ax;
    zeroValue[4] += ay;
    zeroValue[5] += az;
    delay(10);
  zeroValue[0] /= 100;
  zeroValue[1] /= 100;
  zeroValue[2] /= 100;
  zeroValue[3] /= 100;
  zeroValue[4] /= 100;
  zeroValue[5] /= 100;
  zeroValue[5] /= 100; // Z value is -1g when facing upwards - Sensitivity = 0.33/3.3*1023=102.3
 void measure_ANGLE(){
timer = micros();
   gyro.read();
  double gyroXrate = ((gX-zeroValue[0])/14.286); // (gyroXadc-gryoZeroX)/Sensitivity - in quids - Sensitivity = 0.00333/3.3*1023=1.0323
  gyroXangle += gyroXrate*((double)(micros()-timer)/1000000); // Without any filter
  double gyroYrate = ((gY-zeroValue[1])/14.286);
  gyroYangle += gyroYrate*((double)(micros()-timer)/1000000);
  double gyroZrate = ((gZ-zeroValue[2])/14.286);
  gyroZangle += gyroZrate*((double)(micros()-timer)/1000000);
 /* Serial.println(gyroZangle); // This is the yaw
  double accXval = (double)(analogRead(AX)-zeroValue[3]);
  double accYval = (double)(analogRead(AY)-zeroValue[4]);
  double accZval = (double)(analogRead(AZ)-zeroValue[5]);
  // Convert to 360 degrees resolution
  // atan2 outputs the value of -π to π (radians) - see http://en.wikipedia.org/wiki/Atan2
  // We are then convert it to 0 to 2π and then from radians to degrees
  double accXangle = (atan2(accXval, accZval)+PI)*(180/3.14);
  double accYangle = (atan2(accYval, accZval)+PI)*(180/3.14);
 timer = micros();
  /* You might have to tune the filters to get the best values */
  compAngleX = (0.965*(compAngleX+(gyroXrate*(double)(micros()-timer)/1000000)))+(0.035*(accXangle));
  compAngleY = (0.965*(compAngleY+(gyroYrate*(double)(micros()-timer)/1000000)))+(0.035*(accYangle));
 // reset timing
  /* print data to processing */
  //Serial.print(gyroXangle);Serial.print("\t");
  //Serial.print(gyroYangle);Serial.print("\t");
 // Serial.print(accXangle);Serial.print("\t");
 // Serial.print(accYangle);Serial.print("\t");
 Serial.print(compAngleX);Serial.print("\t");
  Serial.print(compAngleY); Serial.print("\t");
  Serial.print(gyroZangle);
  //Serial.print(xAngle);Serial.print("\t");
  //Serial.print(yAngle);Serial.print("\t");
 void roll_compute(){
   measure_ANGLE();
   Y.Compute();
 void pitch_compute(){
   measure_ANGLE();
   X.Compute();
 void yaw_compute(){
   measure_ANGLE();
   Z.Compute();
 void attitude(){
   A.Compute();
 void setup(){
  pinMode(12, OUTPUT);
  pinMode(13, INPUT);
   gyro.enableDefault();
   attach_MOTORS(6,9,10,11);
   delay(2000);
   esc_calib();
X.SetOutputLimits(1060, 1860);
X.SetMode(AUTOMATIC);
Y.SetOutputLimits(1060, 1860);
Y.SetMode(AUTOMATIC);
Z.SetOutputLimits(1060, 1860);
Z.SetMode(AUTOMATIC);
A.SetOutputLimits(1060, 1860);
A.SetMode(AUTOMATIC);
void stabilize_x(){
  if (Measuredx<Setpointx)
   int i= (THROTTLE+(Outputx-MIN_THROTTLE));
    RIGHT(i);
  else if (Measuredx>Setpointx){
    int i=(THROTTLE-(Outputx-MIN_THROTTLE));
    LEFT(i);
    RIGHT(THROTTLE);
    LEFT(THROTTLE);
void stabilize_y(){
  if (Measuredy<Setpointy){
    int i=THROTTLE+(Outputy-MIN_THROTTLE);
    BACK(i);
  else if(Measuredy<Setpointy){
    int i=(THROTTLE-(Outputy-MIN_THROTTLE));
    FRONT(i);
  else{
    FRONT(THROTTLE);
    BACK(THROTTLE);
void stabilize_height(){
  if (Measureda<Setpointa){
    int i=THROTTLE+(Outputa-MIN_THROTTLE);
    FRONT(i);
    BACK(i);
    LEFT(i);
    RIGHT(i);
  else if (Measureda>Setpointa){
   int i=THROTTLE-(Outputa-MIN_THROTTLE);
    FRONT(i);
    BACK(i);
    LEFT(i);
    RIGHT(i);
  else{
    THROTTLE=Outputz;
    FRONT(THROTTLE);
    BACK(THROTTLE);
    LEFT(THROTTLE);
    RIGHT(THROTTLE);
void stabilize_yaw(){
  if (Measuredz<Setpointz){
    int i=THROTTLE+(Outputz-MIN_THROTTLE);
    int j=THROTTLE-(Outputz-MIN_THROTTLE);
    FRONT(i);
    BACK(i);
    LEFT(j);
    RIGHT(j);
  else if (Measuredz>Setpointz){
    FRONT(j);
    BACK(j);
    LEFT(i);
    RIGHT(i);
  else{
     FRONT(THROTTLE);
    BACK(THROTTLE);
    LEFT(THROTTLE);
    RIGHT(THROTTLE);
 void loop(){
pitch_compute();
roll_compute();
yaw_compute();
Serial.println(Outputz);
Serial.print('/t');
Serial.println(compAngleY);
Thanks in advance!! Pls help>> I have only short time to finish this project smiley-cry smiley-cry smiley-cry smiley-cry smiley-cry smiley-sad smiley-sad smiley-sad smiley-sad smiley-sad smiley-sad smiley-sad smiley-sad
« Last Edit: January 27, 2013, 11:16:40 am by deepu1994 » Logged
Poole, Dorset, UK
Offline Offline
God Member
View Profile
What would help is to use the auto format option in the IDE and then repost the code.
Mark
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
You have to tell us that. The code you posted does something. You want it to do something. If those two somethings were the same thing, you wouldn't have posted. So, all we know is that the code you posted does not do what you want. But, we don't know what it does or what you want it to do.
I hope you understand that there can be a lllooonnnggg time between sending an SMS and that SMS being received. I've gotten text messages 2 days after they were sent. Your quadrotor may have crashed and burned waiting for a text message.
Logged
India
Offline Offline
Newbie
View Profile
Actual thing that is happening is when i upload my sketch to my uno rev3, IDE replies me with "done uploading".So after uploading , as for my code there should be response of showing me the angle calculated and the throttle response,, but it doesn't>>>
kepps still and no sound on esc's and motors too>>>
and >>>
my project doesn't mean that i should send message for "take off " ,"right", blah blah>> but i send messages like "roam" "revolute" etc......
Logged
India
Offline Offline
Newbie
View Profile
Auto format  doesn't help>> still no response
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
 One thing that comes to mind is that most ESCs require a specific startup 'arming' sequence before the ESC will except servo commands and turn on motors, it's a safety feature so you don't have spinning props turning on when you first power up the ESC/motor combination. I see no such ESC arming function in your sketch?
Lefty
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Which Arduino are you using? Have you measured how much free memory you have?
That's a lot of code, and variables, for anything less than a Mega.
Logged
East Anglia (UK)
Offline Offline
Edison Member
May all of your blinks be without delay
View Profile
Nothing to do with your problem, but I am interested what the esc_calib() function does.  All it appears to do is to run each motor slowly in turn for 1 second each.  How is the calibration achieved ?
Logged
Offline Offline
Brattain Member
View Profile
That may indeed be the ESC arming sequence need for his specific ESCs, set 0% throttle for at least one sec? However he has commented out the calling of that function in his sketch?
Lefty
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
I can't get your code to compile to test, so I suggest you check the amount of memory your code is requiring. Also, you probably need to put some degugging steps in the code to send expected info back to the serial monitor for verification. Have you been able to arm your ESC using simple serial test code?
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
India
Offline Offline
Newbie
View Profile
As per my esc , it needs minimum throttle for at least a second.... so when i send the lowest throttle it arms which noted as esc_calib();
i have a plenty of memory IDE shows
Binary sketch size: 11,878 bytes (of a 32,256 byte maximum)
Logged
India
Offline Offline
Newbie
View Profile
 sry guyz my actual problem is the serial monitor response >> it doesn't respond anything >>> which works well with other sketchs that uses serial monitor>>>>>
I m using arduino uno rev3 equipped with atmega 328
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
No, you have plenty of code space. SRAM, were variables are stored, is completely separate from program space.
Logged
Offline Offline
Brattain Member
View Profile
But you show a
Code:
//esc_calib();
in your setup function, so you are not performing the function?
Logged
0
Online Online
Tesla Member
Arduino rocks
View Profile
Very simple servo test code to test your ESC arming.
Code:
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  myservo.writeMicroseconds(1500); //set initial servo position if desired
  myservo.attach(7);  //the pin for the servo control
  Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured string
    int n = readString.toInt();  //convert readString into a number
    // auto select appropriate value, copied from someone elses code.
    if(n >= 500)
      Serial.print("writing Microseconds: ");
      Serial.println(n);
      myservo.writeMicroseconds(n);
      Serial.print("writing Angle: ");
      Serial.println(n);
      myservo.write(n);
    readString=""; //empty for next input
Logged
Pages: [1] 2   Go Up
Print
Jump to:
