Topic: Sending Data to a Mysql WebServeur using POST method (Read 30466 times) previous topic - next topic
rockwallaby
@JohnHoward,
Please carefully read my reply #11, re trying without using DHCP, and understand the configuration of your router(s) between Arduino and server.
Also my reply #13, your initial problem of connection issues had little to with what the OP, royalldonkey was asking and so we are mixing up this thread with multiple issues.
@royalldonkey, can you tell us your status?
Paul - VK7KPA
JohnHoward
@JohnHoward,
Apparently I need to explicitly say I was trying to solve the OP's problem for him, hence "my POST above should do what you are trying to do."  And I thought I had, with one reservation which I had noted. It's not terribly polite to lash out at someone about 'thread hijacking' for simply trying to help.  Or at any time, really.
royalldonkey
Hi everyone,
thank you for your precious help.
I managed to get the code to work by using SurferTim web client code, that you can find where:
http://playground.arduino.cc/Code/WebClient
thanks you every much.
rockwallaby
Hi Anthony,
That's good news, well done.
Just to let you know, the code I posted above for the Arduino POST method is based on SurferTim's code of WebClient.
Thanks for letting us know, much appreciated.
Santé
Paul
Paul - VK7KPA
ashishwazarkar
hello sir,
thank you for your code
i try it on php but want  use asp.net c# for storing data in mysql data base than what can i do ?
help me..
SurferTim
Should be no different for an asp server on the Arduino end, just the page name is different. Don't know about the asp C# code tho.
tolerance_zero
Is there any easy example how to send data using Post method and then php script put this data to mysql database?
Or can somebody help me doing it?
gpsmikey
One advantage (at least that looks like it to me) of using GET instead of POST for initial experimenting/testing is the very same thing that is a disadvantage to GET - it is visible as part of the URL.  That feature makes it very easy to simply create a test url in your browser that passes whatever data you want along to your test page.  You just add the "?var1=something" for example then your web page can be looking for "var1".  You can easily change the data being passed (even bookmark it if you want) to try different values of things.  It wasn't obvious to me how to easily generate a test using POST from a simple browser.
mikey
-- you can't have too many gadgets or too much disk space !
old engineering saying: 1+1 = 3 for sufficiently large values of 1 or small values of 3
