Loading...
Pages: [1]   Go Down
Author Topic: Arduino PWM only putting out 3.6Volts  (Read 298 times)
Offline Offline
Newbie
View Profile
I'm using the command
analogWrite(ledManual, 255);
and have the pins connected so they attach to the led positive in, a series 20ohm resistor, and then ground on the Arduino MEGA board. When I read the voltage from pin 2 to ground directly I get 5volts but when I connect them to the resistor, I only get 3.6 volts. Approximately 0.7 over the led and 2.9V over the resistor. Does anyone know why this is happening?
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Your series resistor is WAY too small.  You are drawing 145 mA (2.9 Volts / 20 Ohms) from a pin that has an absolute maximum rating of 40 mA!
Logged
Offline Offline
Edison Member
View Profile
Quote
You probably want to read the datasheet.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Are you sure of that? Most visible light LEDs have a minimum voltage of at least 1.2V. Is it an IR LED?
If you need to drive your LED that hard you need a transistor.
Logged
Offline Offline
Newbie
View Profile
Thank you! I didn't even think of that, the LED isn't even in the final project. I was just using it for testing of code, I grabbed a resistor out of the network and put it in series without even thinking about it but yes that was the reason.
On a note of the voltage, your right. I reversed them. The resistors only dropping 700-800mV, and the LEDs dropping the rest. I'm not sure why the led is dropping so much, perhaps because the resistor was so low.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Perhaps it's the color of the led you are using as they have very different Vf ratings between the color choices.
So what kind of led are you using?
Lefty
Logged
Pages: [1]   Go Up
Print
Jump to:
