Topic: Using serial.print to debug a library (Read 7902 times) previous topic - next topic
fretless_kb
I'm trying to clean up some code I wrote by splitting it into separate files either in tabs or ultimately into a library. I have a lot of debug statements that print to the console and I'm wondering how to pass a serial object reference to the library. I found some simple examples (but can no longer find the thread) so I'll re-post them here.  The code compiles o.k. when it's all in the main tab but as I tried splitting it into 3 tabs (.ino, .c &.h) I get a compiler error.
myLibrary.c:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'MyLibrary'
Here's the whole piece of code.
Code: [Select]
class MyLibrary {
  public:
    //pass a reference to a Print object
    MyLibrary( HardwareSerial &print ) {
      printer = &print; //operate on the adress of print
      printer->begin(9600);
    void test() {
      printer->println("Hello library with serial connectivity!");
  private:
    HardwareSerial* printer;
MyLibrary myLibrary(Serial);
  myLibrary.test();
void loop() {}
Here's how I tried to split it up first the .ino file
Code: [Select]
#include "myLibrary.c"
  myLibrary.test();
  delay(10);
  myLibrary.test();
Then the .h file
Code: [Select]
#ifndef _EXAMPLE_SPLIT_H
#define _EXAMPLE_SPLIT_H
#endif
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include "HardwareSerial.h"
class MyLibrary {
  public:
    MyLibrary( HardwareSerial &print );
    void test() ;
  private:
and finally the .c file
Code: [Select]
class  MyLibrary {
  public:
    void test() {
  private:
Any suggestions on how to pass the serial class by reference into a library in a separate file?
Cheers Kb
PaulS
First question is why are you using a c file? The Arduino is programmed in C++, which uses cpp as the extension. There is a huge difference in the way the c compiler produces object code and the way that the cpp compiler produces object code.
C doesn't have classes, so putting the class implementation in a c file doesn't make sense.
fretless_kb
Well That's embarrassing, I've been working on Vex robots mostly, and when using the Arduino just worked in a single file.  I did switch to .cpp file extension and I get different (but somewhat similar) errors. I also noticed I posted the wrong example of my Library split amongst files.
The corrected posting is below:
.ino file
Code: [Select]
#include "MyLibrary.h"
  myLibrary.test();
void loop() {}
.h file
Code: [Select]
#endif
#else
#endif
class MyLibrary {
  public:
    void test();
  private:
.cpp file
Code: [Select]
class MyLibrary {
  public:
    void test() {
  private:
Errors reported by the compiler:
MyLibrary.cpp:3: error: expected `)' before '&' token
MyLibrary.cpp:11: error: ISO C++ forbids declaration of 'HardwareSerial' with no type
MyLibrary.cpp:11: error: expected ';' before '*' token
MyLibrary.cpp: In member function 'void MyLibrary::test()':
MyLibrary.cpp:8: error: 'printer' was not declared in this scope
I would appreciate any help resolving the first 2-3 errors The last error looks to be caused by the first error not being resolved.
Thanks - Kb
PaulS
The cpp file has no idea what a HardwareSerial is. You need to include the header file in the source file.
fretless_kb
Thanks for your help PaulS,
I've included the Hardware serial header in the file but I still get errors.
HardwareSerialClassExampleSplit.cpp.o: In function `__static_initialization_and_destruction_0':
C:\Users\Kb\AppData\Local\Temp\build6312645766259194773.tmp/HardwareSerialClassExampleSplit.cpp:5: undefined reference to `MyLibrary::MyLibrary(HardwareSerial&)'
HardwareSerialClassExampleSplit.cpp.o: In function `setup':
C:\Users\Kb\AppData\Local\Temp\build6312645766259194773.tmp/HardwareSerialClassExampleSplit.cpp:8: undefined reference to `MyLibrary::test()'
I had another window open and had a typo including the MyLibrary.cpp file vs the MyLibray.h file and that version compiles.  I don't think that what I'm supposed to do though is it?
So the version which includes the .h file and spits out the above errors is:
Code: [Select]
  myLibrary.test();
void loop() {}
The one that compiled clean is:
Code: [Select]
#include "myLibrary.cpp"
  myLibrary.test();
  delay(10);
  myLibrary.test();
In both cases I modified the .cpp file to read
Code: [Select]
class MyLibrary {
  public:
    void test() {
  private:
PaulS
Code: [Select]
You should not be including source files in sketches. You only include header files.
File names are case sensitive. myLibrary.cpp and MyLibrary.h don't play together.
fretless_kb
Code: [Select]
Agreed, That is not what I intended, so back to the current compilation errors;
C:\Users\Kb\AppData\Local\Temp\build6312645766259194773.tmp/HardwareSerialClassExampleSplit.cpp:7: undefined reference to `MyLibrary::MyLibrary(HardwareSerial&)'
C:\Users\Kb\AppData\Local\Temp\build6312645766259194773.tmp/HardwareSerialClassExampleSplit.cpp:9: undefined reference to `MyLibrary::test()'
Any idea why I am getting an undefined reference to `MyLibrary::MyLibrary(HardwareSerial&) error?
Cheers Kb
fretless_kb
So just to recap I seem to be having linker errors for this example to use the Serial.print function from a library as coded in multiple tabs in a sketch:
.ino file
Code: [Select]
  myLibrary.test();
void loop() {}
.cpp file
Code: [Select]
class MyLibrary {
  public:
      printer = &print; //operate on the address of print
    void test() {
  private:
.h file
Code: [Select]
#endif
#else
#endif
class MyLibrary {
  public:
    void test();
  private:
Errors:
C:\Users\Kb\AppData\Local\Temp\build5255053454461430477.tmp/HardwareSerialClassExampleSplit.cpp:7: undefined reference to `MyLibrary::MyLibrary(HardwareSerial&)'
C:\Users\Kb\AppData\Local\Temp\build5255053454461430477.tmp/HardwareSerialClassExampleSplit.cpp:11: undefined reference to `MyLibrary::test()'
Thanks in advance for advice on how to resolve this or if this is not allowed for some reason.
Cheers Kb
PaulS
There are many bugs in that last stuff you posted. The sketch looks fine. The source file looks like a header file. The header file has an include guard that is useless.
MyLibrary.h should look like:
Code: [Select]
#ifndef _MYLIBRARY_H
#define _MYLIBRARY_H
#else
#endif
class MyLibrary {
 public:
   void test();
 private:
#endif
It's hard to say what MyLibrary.cpp should look like, at this point. At a minimum, it needs to #include MyLibrary.h.
WizenedEE
Your .cpp file should not have the class definition. It should look like this:
Code: [Select]
MyLibrary::MyLibrary( HardwareSerial &print ) {
MyLibrary::void test() {
PaulS
Quote
Really? No need to include MyLibrary.h?
fretless_kb
Thanks I will try these and re-post.  Just a quick response, when I included the MyLibrary.h file in the .cpp file I got duplicate class definitions.  That should have been telling in the first place. but I haven't used C++ in almost 15 years.
PaulS
Quote
The #ifndef/#define/#endif statements prevent multiple inclusions of the same code. That is why the class definition is between the ifndef statement and the endif statement. Moving the endif statement to the top of the file made the guard useless, since it was no longer guarding anything.
fretless_kb
O.k. Got the point on the guard, I actually needed 2 #endif at the end.  I got the code to compile, but it does not print to the serial port. I had to change the baud rate from the previous example to match my current setup:
Here's the final three pieces which compile.
.ino ( I added a call to test and a delay in the loop)
Code: [Select]
  myLibrary.test();
  myLibrary.test();
.cpp (Corrected, thanks for the corrections, I did need to include MyLibrary.h)
Code: [Select]
      printer->begin(115200);
    void MyLibrary::test() {
And Header with the second #endif added to the bottom of the file
Code: [Select]
#else
#endif
class MyLibrary {
  public:
    void test();
  private:
#endif
Now to try to find out why it doesn't output anything to the port. - Thanks again - Kb
PaulS
Quote
Well, that's easy. When is your class constructor called? When is the HardwareSerial constructor called? You don't know, do you? Therefore, you should not write code that relies on them being called in the correct order.
You need a begin() method in your class. You pass nothing to the constructor. You pass a serial instance to the begin method. You call the begin method in the setup() function.
