Loading...
Pages: 1 [2]   Go Down
Author Topic: Using serial.print to debug a library  (Read 451 times)
Offline Offline
Newbie
View Profile
Ah Thanks I will clean that up, That would be better practice eh?  I appreciate the feedback. - Kb
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Well, it's better in the sense that it is absolutely necessary, so, yeah.
Logged
Offline Offline
Newbie
View Profile
Quote
Now to try to find out why it doesn't output anything to the port.
Well, that's easy. When is your class constructor called? When is the HardwareSerial constructor called? You don't know, do you? Therefore, you should not write code that relies on them being called in the correct order.
You need a begin() method in your class. You pass nothing to the constructor. You pass a serial instance to the begin method. You call the begin method in the setup() function.
So I'm trying to learn and I appreciate your patience and help, but I don't quite follow the recommendation to pass nothing to the constructor.  I went to the C++ tutorial website here: http://www.cplusplus.com/doc/tutorial/ and reviewed examples of constructors and destructors  for classes.  I tested a few things. I Thought the constructor, being outside of setup() or loop(), is called first. and therefore passing the Serial object to the library when declaring an instance seemed reasonable.
I tried to construct an example where I did not pass Serial in the constructor, but I could not get it to compile.  However I was successful in creating an example where I pass Serial in the constructor (for the instance myLibrary) and later calling a begin() function.
This code works, Is there some reason it is incorrect?
.ino
Code:
#include "MyLibrary.h"
MyLibrary myLibrary(Serial);
  myLibrary.begin();
  myLibrary.test();
  myLibrary.test();
.cpp
Code:
#include "HardwareSerial.h"
    //pass a reference to a Print object
    MyLibrary::MyLibrary( HardwareSerial &print ) {
      printer = &print; //operate on the address of print
    void MyLibrary::begin() {
      printer->begin(115200);
    void MyLibrary::test() {
      printer->println("Hello library with serial connectivity!");
and .h
Code:
#ifndef _MYLIBRARY_H
#define _MYLIBRARY_H
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
class MyLibrary {
  public:
    MyLibrary(HardwareSerial &print);
    void begin( );
    void test();
  private:
    HardwareSerial* printer;
#endif
My Other code does not But I was unsure what to put in the coonstructor I tried it 2 ways, with nothing (assuming the pointer to HardwareSerial has storage already assigned so it could safely be pointed to, and one declaring storage for the Hardware serial, but I get compiler errors trying to pass Serial in the begin call.
Here's the last round of my attempt to not pass anything in the constructor and pass the reference in the call to begin. I'm not following how to code what you suggested.
.ino
Code:
MyLibrary myLibrary();
  myLibrary.begin(Serial);
  myLibrary.test();
  myLibrary.test();
.cpp
Code:
    MyLibrary::MyLibrary(  ) {
    printer = new HardwareSerial;
    MyLibrary::~MyLibrary(  ) {
    delete printer;
    void MyLibrary::begin(HardwareSerial &print) {
.h
Code:
#else
#endif
class MyLibrary {
  public:
    MyLibrary();
    ~MyLibrary();
    void begin(HardwareSerial &print);
    void test();
  private:
#endif
Errors:
HardwareSerialClassExampleSplit_V2.cpp: In function 'void setup()':
HardwareSerialClassExampleSplit_V2:6: error: request for member 'begin' in 'myLibrary', which is of non-class type 'MyLibrary ()()'
HardwareSerialClassExampleSplit_V2:7: error: request for member 'test' in 'myLibrary', which is of non-class type 'MyLibrary ()()'
HardwareSerialClassExampleSplit_V2.cpp: In function 'void loop()':
HardwareSerialClassExampleSplit_V2:10: error: request for member 'test' in 'myLibrary', which is of non-class type 'MyLibrary ()()'
Note if the example I posted first is 'safe' I'm happy to code it per that example. if there is something inherently dangerous in that approach even though it works please point that out.  - Thanks again - Kb
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
It does, and it would, IF you knew that the HardwareSerial instance had been created. Do you KNOW that? Or, are you only hoping that your constructor gets called after the HardwareSerial constructor?
Code:
Here you are passing a possibly unvalued variable to the constructor of your class. Does that really seem like a good idea?
It would be so much easier to pass a pointer to your class than to pass an instance to your class. Why is that not an acceptable possibility?
Logged
Chicago
Offline Offline
Jr. Member
Arduino rocks
View Profile
Paul
If you passed a pointer instead of a instance would you test to see if the pointer = NULL in the class member Begin()? before trying to use it. I'm trying to follow along here so get more experience.
I wonder of possible use myself.
Don
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Yes, and anywhere else you want to dereference the pointer:
Code:
if(printer)
  printer->print("whatever");
Logged
Offline Offline
Newbie
View Profile
Code:
I hear what your saying, and I believe in a C++ program I should be able to deterministically tell the order of creation, but I have no idea what the Arduino IDE is doing under the hood. so I made some assumptions as bad as that might seem.
If I pass a pointer to my class of type HardwareSerial I still need to ensure the Serial class is created first.
I'll need to think on this for a while.  Thanks for your input today.
Cheers Kb
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
It's not bad, as long as you understand that they are assumptions, and that you are will to make changes when the assumptions prove incorrect.
Quote
That depends. If you (try to) pass the pointer to the constructor, then, yes, it is a problem. If, instead, you pass the pointer to the begin() method, and you call the begin() method in setup(), then you can be confident that the Serial instance will exist, and you can pass a pointer to it to your method.
Logged
Offline Offline
Newbie
View Profile
Well I seem to be stuck trying to implement what you are referring to.  I understand that if I don't declare a constructor C++ will create a default one for me so in this simple example I should be able to get away with not declaring a constructor. so I re-wrote the example to call the constructor with no arguments, I created a begin function which should accept a HardwareSerial pointer. But When I compile this I get compiler errors.
.ino
Code:
  HardwareSerial* hwPrint;
  hwPrint = &Serial;
  myLibrary.begin(hwPrint);
  myLibrary.test();
  myLibrary.test();
.cpp
Code:
    void MyLibrary::begin(HardwareSerial* hwPrint) {
      printer = hwPrint; //operate on the address of print
      if(printer) {
      if(printer) {
.h
Code:
#else
#endif
class MyLibrary {
  public:
    void begin(HardwareSerial* hwPrint);
    void test();
  private:
#endif
Errors:
HardwareSerialClassExampleSplit_V2:8: error: request for member 'begin' in 'myLibrary', which is of non-class type 'MyLibrary ()()'
HardwareSerialClassExampleSplit_V2:9: error: request for member 'test' in 'myLibrary', which is of non-class type 'MyLibrary ()()'
HardwareSerialClassExampleSplit_V2:12: error: request for member 'test' in 'myLibrary', which is of non-class type 'MyLibrary ()()'
This is probably something trivial, but I can't seem to find a good reference to what the error is cause by.
Cheers Kb
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Code:
The parentheses are needed to pass arguments to the constructor. If there are no arguments, there are no parentheses.
Remove them, and see what that does to the error messages.
Logged
Offline Offline
Newbie
View Profile
Thanks, That solves it. No errors and the code functions, i.e. I get prints to the serial port.
Thanks again so much.  Now on to designing my library properly. (that could take a while) But I really appreciate learning how to use these objects correctly.
Cheers Kb
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Great. It's easy after 30 years.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
