Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Serial monitor infinite output  (Read 661 times)
Offline Offline
Newbie
View Profile
here's what my output is
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I'm confused about what the device is, still. As in, its part number.
You don't generally connect things via a single wire. Does the device have a ground wire? Is it wired to the Arduino ground?
Quote
i don't have a photo or a schematic sir,
Do you have a phone with a camera in it? How about using it?
Quote
I believe you. You don't have to attach a screenshot. You can copy and paste from the output window.
Logged
Offline Offline
Newbie
View Profile
here's what the device is... i bet it is just newly constructed so got no full ideas about it.
http://www.e-gizmo.com/KIT/NEWIR.htm
but i will try all your suggestions now sir...thanks a lot. u guys got my sincere gratitudes smiley-red
Logged
Offline Offline
Newbie
View Profile
http://www.e-gizmo.com/KIT/images/11functions/11%20function%20technical%20manual.pdf
found this manual sirs
Logged
Offline Offline
Newbie
View Profile
Code:
  pinMode(forwardPin, INPUT);
  digitalWrite(forwardPin, HIGH); // Turn on the pullup resistor.
so the new code will be like this?
Code:
int forwardPin = 12;
  int forwardState = digitalRead(forwardPin);
  if (forwardState == HIGH)
    Serial.println("HIGH");
    Serial.println("LOW");
Logged
California
Online Online
Edison Member
View Profile
Why not try it and tell us?
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
With those 1 second delays you're not going to read more than the fact a signal was sent from the remote and that only by luck.
Try keeping track of what state the pin was last time it was read and only printing when the state changed. Then take the delays out. But fix the wiring first.
Logged
Examples can be found at Learning in the Main Site and at the Playground
Offline Offline
Newbie
View Profile
Code:
will it also work if i make it a pull down resistor? some like...
Code:
  digitalWrite(forwardPin, LOW); // Turn on the pulldown resistor
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
No, there are no built in pulldowns
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
thanks sir that helped a lot ^^
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
digitalWrite(forwardPin, LOW);   // turn off the pull-up resistor
All that second line does is turn off the pull-up. There had to be a way of doing it, and this is it.
Logged
Offline Offline
Newbie
View Profile
Code:
oh really sir?! gee thanks! i will try it now
Logged
Beijing
Offline Offline
Full Member
Skype name habib.derbyshire
View Profile
WWW
Do you know how to wire a pull-down resistor?
Logged
What is man's best friend? The breadboard!
Offline Offline
Newbie
View Profile
yes sir i read about it
Logged
Beijing
Offline Offline
Full Member
View Profile
WWW
I'm really not used to someone calling me sir smiley smiley smiley check my profile. Just call me Habib  smiley
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
