« Reply #15 on: January 27, 2013, 11:14:03 pm » |
 here's what my output is
Melbourne, Australia
Shannon Member
Lua rocks!
« Reply #16 on: January 27, 2013, 11:16:06 pm » |
I'm confused about what the device is, still. As in, its part number. You don't generally connect things via a single wire. Does the device have a ground wire? Is it wired to the Arduino ground? i don't have a photo or a schematic sir, Do you have a phone with a camera in it? How about using it? here's what my output is I believe you. You don't have to attach a screenshot. You can copy and paste from the output window.
« Reply #17 on: January 27, 2013, 11:22:34 pm » |
here's what the device is... i bet it is just newly constructed so got no full ideas about it. http://www.e-gizmo.com/KIT/NEWIR.htmbut i will try all your suggestions now sir...thanks a lot. u guys got my sincere gratitudes
« Reply #18 on: January 27, 2013, 11:31:31 pm » |
« Reply #19 on: January 28, 2013, 12:10:55 am » |
pinMode(forwardPin, INPUT); digitalWrite(forwardPin, HIGH); // Turn on the pullup resistor. so the new code will be like this? int forwardPin = 12;
void setup() { Serial.begin(9600); pinMode(forwardPin, INPUT); digitalWrite(forwardPin, HIGH); }
void loop() { int forwardState = digitalRead(forwardPin); if (forwardState == HIGH) { Serial.println("HIGH"); delay(1000); } else { Serial.println("LOW"); delay(1000); } }
California
Online
« Reply #20 on: January 28, 2013, 12:20:16 am » |
Why not try it and tell us?
Pittsburgh, PA, USA
I only know some basic electricity....
« Reply #21 on: January 28, 2013, 01:04:03 am » |
With those 1 second delays you're not going to read more than the fact a signal was sent from the remote and that only by luck.
Try keeping track of what state the pin was last time it was read and only printing when the state changed. Then take the delays out. But fix the wiring first.
Examples can be found at Learning in the Main Site and at the Playground
« Reply #22 on: January 28, 2013, 12:15:14 pm » |
pinMode(forwardPin, INPUT); digitalWrite(forwardPin, HIGH); // Turn on the pullup resistor. will it also work if i make it a pull down resistor? some like... pinMode(forwardPin, INPUT); digitalWrite(forwardPin, LOW); // Turn on the pulldown resistor
UK
« Reply #23 on: January 28, 2013, 12:17:31 pm » |
No, there are no built in pulldowns
« Reply #24 on: January 28, 2013, 12:37:14 pm » |
thanks sir that helped a lot ^^
Shannon Member
Lua rocks!
« Reply #25 on: January 28, 2013, 03:27:48 pm » |
pinMode(forwardPin, INPUT); digitalWrite(forwardPin, LOW); // turn off the pull-up resistor
All that second line does is turn off the pull-up. There had to be a way of doing it, and this is it.
« Reply #26 on: January 28, 2013, 09:36:16 pm » |
All that second line does is turn off the pull-up. There had to be a way of doing it, and this is it. oh really sir?! gee thanks! i will try it now
Beijing
Skype name habib.derbyshire
« Reply #27 on: January 28, 2013, 09:48:42 pm » |
Do you know how to wire a pull-down resistor?
What is man's best friend? The breadboard!
« Reply #28 on: January 28, 2013, 09:58:07 pm » |
yes sir i read about it
Beijing
« Reply #29 on: January 28, 2013, 10:22:55 pm » |
