Topic: Serial monitor infinite output (Read 7925 times) previous topic - next topic
zer0_JuLz
nickgammon
I'm confused about what the device is, still. As in, its part number.
You don't generally connect things via a single wire. Does the device have a ground wire? Is it wired to the Arduino ground?
i don't have a photo or a schematic sir,
Do you have a phone with a camera in it? How about using it?
here's what my output is
I believe you. You don't have to attach a screenshot. You can copy and paste from the output window.
zer0_JuLz
here's what the device is... i bet it is just newly constructed so got no full ideas about it.
http://www.e-gizmo.com/KIT/NEWIR.htm
but i will try all your suggestions now sir...thanks a lot. u guys got my sincere gratitudes :smiley-red:
zer0_JuLz
http://www.e-gizmo.com/KIT/images/11functions/11%20function%20technical%20manual.pdf
found this manual sirs
zer0_JuLz
  pinMode(forwardPin, INPUT);
  digitalWrite(forwardPin, HIGH); // Turn on the pullup resistor.
so the new code will be like this?
int forwardPin = 12;
  int forwardState = digitalRead(forwardPin);
  if (forwardState == HIGH)
    Serial.println("HIGH");
    Serial.println("LOW");
Arrch
Why not try it and tell us?
GoForSmoke
With those 1 second delays you're not going to read more than the fact a signal was sent from the remote and that only by luck.
Try keeping track of what state the pin was last time it was read and only printing when the state changed. Then take the delays out. But fix the wiring first.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
zer0_JuLz
will it also work if i make it a pull down resistor? some like...
  digitalWrite(forwardPin, LOW); // Turn on the pulldown resistor
AWOL
No, there are no built in pulldowns
zer0_JuLz
thanks sir that helped a lot ^^
nickgammon
digitalWrite(forwardPin, LOW);   // turn off the pull-up resistor
All that second line does is turn off the pull-up. There had to be a way of doing it, and this is it.
zer0_JuLz
oh really sir?! gee thanks! i will try it now
arduinohabib
Do you know how to wire a pull-down resistor?
What is man's best friend? The breadboard!
zer0_JuLz
yes sir i read about it
arduinohabib
I'm really not used to someone calling me sir :) :) :) check my profile. Just call me Habib  :)
