Topic: Max31855 Internal temp strange value (Read 985 times) previous topic - next topic
jmaxado
I am using a shield with the MAX31855 with the library from adafruit with my arduino duemilanove.
Using the library example "serialthermocouple" I have measurments of the internal temp of the max31855 about 15 degrees higher than it is supost to be
Using a mixure of water and ice that has a temp o 0º I get measurments of the temp os the thermocouple about 15 ºc.
Does this means my shield is broken ? Or am I doing something wrong ?
Thanks in advance
José
robtillaart
Do you have a link to the code?
If the reading is constant 15° too high there might be an error in the code, or there is a need for calibration?
Do you have other readings that confirm a 15° offset?  (e.g. room temp, cooking water, body temp 37C etc)
Rob Tillaart
jmaxado
Thanks for the reply
Today I figure out that something is wrong, maybe with the max31855.
I will check and get back with news.
Jose
