Loading...
Pages: [1]   Go Down
Author Topic: NFC reader pin 9,10,11,12 can still be used for other application?  (Read 80 times)
universe
Offline Offline
Sr. Member
I'm enjoying my Life
View Profile
WWW
I just bought NFC reader from: http://www.seeedstudio.com/wiki/NFC_Shield_V1.0
It is stated that: SPI interface. Hence, most Arduino pins are available for other applications
So can I still be used pin 9,10,11,12 for other bit transfer because it has already use SPI?
Or I cant?
Thank you!!!
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Pins 11, 12, and 13 are the SPI bus pins. You can connect more than one SPI device to those pins, as long as each has a different SS (slave select) pin. Pin 10 needs to be set as an OUTPUT pin (and otherwise not used, except possibly as a SS pin) to define that the Arduino is the SPI master.
You can use these pins to talk to any number of SPI devices, but not for other purposes while there is a SPI device in use.
Logged
Pages: [1]   Go Up
Print
Jump to:
