Loading...
Pages: [1] 2   Go Down
Author Topic: Can I secure my code from being copied on arduino boards?  (Read 892 times)
Offline Offline
Newbie
View Profile
Am brand new to arduino boards, just want to see if it will ba applicable for me to use them.
I want to know if the code that is uploaded to the board can be secured from copying. Perhaps locked to the particular board that it is installed on.
My ideal scenario is that I get some sort of unique board number from the board, then insert that serial number into the code somewhere, and the code checks the board's unique id on boot, if the board does not match then it does not run. This is of course dependant on whether the code within the board can also be protected from view.
thanks
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
1. See section 28 of the datasheet for a discussion of the Lock Bits that are provided.  You can make it difficult to copy the flash memory.
2. I imagine you will need some sort of external PROM to hold the unique number to be checked. I would think that faking the input to provide that wouldn't be all that difficult. Or even just pulliing the part off and reading all the memory locations out the same way the arduino does.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Your code is compiler and linked, and the hex file that the linker produces is uploaded to the board. That binary file can not be converted back into C++ code.
What is your real fear?
Logged
California
Offline Offline
Sr. Member
View Profile
WWW
The arduino board is open source. Your project is not unless you make it so. As long as you don't share your files with anyone no one can see your code. And if someone really really wanted to go to some trouble they could maybe duplicate your chip. If that is a concern then CrossRoads' suggestion of Lock Bits would be of use to you.
Logged
Toledo, OH
Offline Offline
Sr. Member
View Profile
WWW
You can protect yourself from "kid sister" type attacks.  But, if you need military-grade protection, forget it.  Also, keep in mind that just about any protection scheme can be broken with enough time and computer power.
I design military and hipaa-level security systems with the full knowledge that all *can* be hacked.  The goal being, that while it can be hacked, it would take as long as the universe is old to it.  We consider this length of time "infinite".  Basically, while possible, it's not really possible within the age of the universe (since the big bang).
Basically, if you need "kid sister" protection, you can do it.  But, if you need military-level protection, I think you need to look elsewhere.
Tim
Logged
Arduino Uno - Teensy 2.0 - Teensy 3.0 - Raspberry Pi Model B w/512MB RAM
My libraries: NewPing library - LCDBitmap library - toneAC library - NewTone library
Offline Offline
Newbie
View Profile
thanks all,
I did not know if anyone could just plugin and copy the code.
My application is not complicated, but the industry is competitive, I just want basic protection from someone casually copying my solution. If someone wants to copy my solution, then I want them to at least do their own coding.
thanks again. Looks like Arduino is a good choice for me.
Logged
Offline Offline
Newbie
View Profile
thanks to PaulS
the info about compiler and code being linked is key for me, and I hope I understand that correctly.... it means that only the same compiler install can open the code on the chip correct?
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
No. If the flash contents can be read then they can be copied to another chip or disassembled.
But what I read about lock bits says you can keep the flash from being read and that to break the lock bits wipes the flash. Perhaps someone has a way to get the flash out of the chip and read it but I have to wonder at the tools and time that would take and if the effort would be worth the reward as opposed to reverse-engineering or writing a better program or just buying the original.
Logged
Examples can be found at Learning in the Main Site and at the Playground
SG
Offline Offline
Sr. Member
Arduino rocks
View Profile
Atmel AVR231: AES Bootloader
Download software
Quote
This application note describes how firmware can be updated securely on AVR
microcontrollers with bootloader capabilities. The method uses the Advanced
Encryption Standard (AES) to encrypt the firmware.
This application note presents techniques that can be used when securing a design
from outside access. Although no design can ever be fully secured it can be
constructed such that the effort required to break the security is as high as possible.
There is a significant difference between an unsecured design that a person with
basic engineering skills can duplicate and a design that only few, highly skilled
intruders can break. In the unsecured case, the design is easily copied and even
reverse engineered, violating the intellectual property of the manufacturer and
jeopardizing the market potential for the design. In the secured case, the effort
required to break the design is so high that most intruders simply focus on developing
their own products.
Logged
Dubai, UAE
Offline Offline
Edison Member
View Profile
WWW
Quote
that most intruders simply focus on developing their own products.
Quicker and easier - unless your idea is so staggeringly brilliant that no-one could copy the outcome.
Duane B
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Doesn't using a bootloader keep you from using all the locks?
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
I was guessing a yes so once you enable the lock bit, you can no longer upload code with bootloader.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Yes, the standard arduino lock bit values of 0x0F (for locked) and 0x3F (for unlocked) used in most standard boards prevents protection of the flash contents by being read via ICSP, serial bootloader, or even a parallel programmer. Not sure it's possible to be able to lock down the flash contents from being read by a programmer and still be able to utilize a serial bootloader.
 The locked value of 0x0F just protects the bootloader from being erased when a new upload request from the IDE/AVRDUDE erases the old sketch before writing the new sketch to flash memory.
Lefty
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
I wonder if it's possible to get into a fully locked AVR. Can the chip be planed down and somehow read with an electron microscope or like or would it be simpler than that?
Logged
Dubai, UAE
Offline Offline
Edison Member
View Profile
WWW
I think that was done to read the key on an EMV Chip card a few years back.
Duane B
Logged
Pages: [1] 2   Go Up
Print
Jump to:
