Author Topic: LCD contrats variable resistor issue  (Read 283 times)
Belgium
Hello,
I am an arduino beginners ... first starter kit received end of last week.
I'v try to use an 16x2 LCD display.
I did connect a variable resistor to adjust the contrats but when I get a correct contrasted screen, I see some smoke from the resistor ... smiley-eek-blue
It looks like a shortcircuit ? When the resistor is near to 0k ??? I don't understand.
I did try with a 5k var resistor and a 2,2k resistor in serial between 5V and 1 of the 3 pins of the var resistor ... It does not work  smiley-confuse smiley-confuse smiley-confuse
Can someone help me please ?
Thx
Sydney
Big things come in large packages
Did you connect one end of the resistor to gnd, the other end to 5V and the wiper (the one in the middle usually) to the input for the LCD?
Western New York, USA
Except for his use of the term 'resistor' the description for the connections given by marco_c is usually correct since most datasheets call for the use of a potentiometer (a three terminal device) and not a variable resistor (a two terminal device) to control the contrast voltage.
If you were indeed using a potentiometer then you probably had the wiper connected to one of the power supply terminals and, as you adjusted the potentiometer you ultimately got a very low resistance across the power supply terminals, hence the smoke.
Don
« Last Edit: January 27, 2013, 11:04:28 pm by floresta » Logged
Sydney
My bad on the name. Of course it is a pot.
Belgium
Hello
thanks for the quick answers.
My fault ... bad connection on the breadboard ...
And yes it was a potentiomètre.
my apologize smiley-kiss
