Topic: Turning off motors if Serial Communication fails (Read 3694 times) previous topic - next topic
mech_eng
I am in the process of building an ROV and would like to add a safety feature to the code. If the the onboard Arduino stops getting commands over serial I would like to shut if off after 1 second or so of no communication with the surface. I have tried a few things but really am lost here at keeeping track of elapsed time. Here is what I have so far, it does not work, it only reduces motor speed to near zero.
if (Serial.available ()){
    processInput ();
     current = millis();
  if (current-last > interval)
  last = current;
  digitalWrite(M1A, LOW);
  digitalWrite(M1B, LOW);
marco_c
Last needs to be updated when you get a character as this is the last time a clear was received.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
johncc
And also it should not updated when the motors are turned off. (last=current).  You want them to stay off, right?  :)
marco_c
I should have more clearly said it should only be updated when you get a char.  Basically needs to be moved to the if not the else part.
mech_eng
Heres what I have so far:
    processInput ();
    last = millis();
    current = millis();
It still will not shut off the motor, what am I missing?
mech_eng
This works but not without the delay, it only slows the motor without the delay
    processInput ();
    last = millis();
    current = millis();
Here is the whole code:
#include <Servo.h>
Servo servo;
//PINS
const int  M1A = 4; // M1---M4 ARE HORIZONTAL THRUSTERS
const int  M1B = 3;
//INCOMING DATA
const char SOP = '<';
const char EOP = '>';
enum {
  Case, Speed };
//VARIABLES
int whichNumber = Case;
int Casev, Speedv;
int pwmright;            //1
int pwmleft;             //2
unsigned long last;
long interval = 500;
unsigned long current;
void setup ()
  Serial.begin (9600);
  pinMode (M1A, OUTPUT);
  pinMode (M1B, OUTPUT);
void processNumber (int x)
  switch (whichNumber)
  case Case:
    Casev = x;
    whichNumber = Speed;
    break;
  case Speed:
    Speedv = x;
    whichNumber = Case;
    break;
void processInput ()
  static int receivedNumber = 0; //float
  static boolean False = false;
  byte c = Serial.read ();    //byte
  switch (c)
  case EOP:
    if (False)
      processNumber (- receivedNumber);
      processNumber (receivedNumber);
    // fall through to start a new number
  case SOP:
    receivedNumber = 0;
    False = false;
    break;
  case '0' ... '9':
    receivedNumber *= 10;           // receivedNumber = recievedNumber*10 increments decimal places
    receivedNumber += c -'0';      //receivedNumber = recievedNumber + (c - '0') goes from char to decimal
    break;
  case '-':
    False = true;
    break;
void loop ()
  // Check sensors and print values (temperature, depth, accelorometer)
  // Process input, turn off if no data available
    processInput ();
    last = millis();
    current = millis();
    // Test order of recieved commands
    int var1;
    int var2;
    if (Casev < 13) {
      var1 = Casev;
      var2 = Speedv;
    else {
      var1 = Speedv;
      var2 = Casev;
    switch (var1)
      //RIGHT
    case 1:
      pwmright = var2;
      moveright();
      break;
      //LEFT
    case 2:
      pwmleft = var2;
      moveleft();
      break;
    case 3:
//-------------------------------------------------------------------1
void moveright()
  digitalWrite(M1A, HIGH);
  analogWrite(M1B, pwmright);
//------------------------------------------------------------------- 2
void moveleft()
  analogWrite(M1B, pwmleft);
Any way to not use delay?
mech_eng
GOT it, thanks guys
I put the switch inside the if statement and the else after, works like a charm
johncc
Which means it might be even better to put it in processInput().
So then you could write loop() very cleanly as
  int now=millis();
  if (Serial.available())         // Serial Received "Event"
    processInput();
    last=now;  // reset serial timer
  if ( now - last > interval)       // Serial Timer Expired "Event"
    digitalWrite( M1B, LOW);  // turn off motors
Note that "else" is not actually necessary.
Grabbing now=millis() at the start of the loop is a often handy.
Better variable names might include:
last ==>  lastSerialProcessed or serialTimerStarted  (or comm instead of serial)
interval ==>  serialTimeout or serialTimeOutInterval
Cheers,
John
johncc
OH!  And I forgot to mention what got me thinking about variable names....
This is priceless!
  case '-':
    False = true;
    break;
mech_eng
To be honest, I grabbed that part of the code from somewhere on the interwebs and tweaked it to make it work for me. I do not fully understand it, any simple way to explain to me how that part of the code works?
mech_eng
Also, note taken about better variable names
johncc
It looks like it is reading command data (left, right, speed) from Serial in a format like <123><2><-23><1><345>.  What type of device or program is sending to it?
John
