Topic: CodeBlocks Arduino IDE - real C++ IDE for Arduino development (rev.20130827) (Read 123266 times) previous topic - next topic
stanleyhuang
My Arduino blog: http://arduinodev.com/blog
damo1023
Stanley, board is selected properly in Codeblocks and in Arduino builder (mega2560).
It works ok, if I compile, build in Codeblocks and then manually start Arudino builder, choose hex file manually and upload.
I guess something is wrong in codeblocks porting to arduino builder, but all is original settings, I tried some alterations, but no success, then I owerwrite it with original.
Damo
stanleyhuang
So error only occurs when you use Arduino Builder manually?
I recommend downloading a complete Arduino Builder if you want to use it manually.
http://www.downloadbestsoft.com/Arduino-Builder.html
damo1023
No, when I use it manually it works ok.
When it is called from codeblocks error happens.
damo1023
Hello,
me again :).  Stupid windows 7, I think from XP they are getting worse and worse.
I solved the problem - project shouldn't be in the c:\users folder!
ftinetti
Ok, and how do you recompile-rebuild so that the hack starts to work?
TIA,
Fernando.
Actully my long-term goal is to implement a simulator which acts like a http server and use HTML to render the simulation.
About hacking into arduino core files, taking digitalWrite as an example, I just added one line at the end like this:
Code: [Select]
void digitalWrite(uint8_t pin, uint8_t val)
uint8_t timer = digitalPinToTimer(pin);
uint8_t bit = digitalPinToBitMask(pin);
uint8_t port = digitalPinToPort(pin);
volatile uint8_t *out;
if (port == NOT_A_PIN) return;
// If the pin that support PWM output, we need to turn it off
// before doing a digital write.
if (timer != NOT_ON_TIMER) turnOffPWM(timer);
out = portOutputRegister(port);
uint8_t oldSREG = SREG;
cli();
if (val == LOW) {
*out &= ~bit;
*out |= bit;
SREG = oldSREG;
#ifdef ARDUSIM
    fprintf(stderr, "[MCU] Pin %d state changed to %s\n", pin, val ? "HIGH" : "LOW");
#endif
I see them alright, but I'm not sure where should I start from. I guess maybe the simulator could listen to a port for signals?
Could someone give an example using wiring_analog.c?
stanleyhuang
The simulation code is in the core files (a different version). There is no need to rebuild. It is built and linked with sketch.
ftinetti
@stanleyhuang:
Hmmm... if this is a reply to my question, maybe I didn't ask it in the right way. I was asking about your suggestion for hacking the simulator by using code inside
#ifdef ARDUSIM
#endif
which actually I did. However, when I open the ardusim.cbp with the Code::Blocks you provide I obtain a lot of errors (I could send the compiler-linker report, just ask). I've finally got to simulate a digital pin input from file, but doing some extra-hacking stuff, which I prefer not to send, since I think I'm doing something wrong with ardusim.cbp and I would like to fix it.
TIA,
Fernando.
ArduinoNewbie123
Newbie here...testing driving the Arduino CB IDE...how does one send a command/message via the Arduino Builder serial interface??? I can upload the sketch successfully, and can open a serial port at the desired baudrate, but how do I send a command to the Arduino??? Serial.print()?
I am working on a exercise where you instruct RGB LED's to turn on to a set level....using the serial interface in Arduino IDE I can successfully change the LEDs but at a sticking point via the CB Arduino IDE...thanks.
rsk22
Stan -
Great work on the Code::Blocks for Arduino.  I had some difficulty getting the software to work on Windows 7 at first, however I was able to find a work around.  Here is was my original problem.  When I try to do a "build and run" from  Code::Blocks for the blink example, the Arduino Builder pops up.  Afterwards, I click COM3 but it gives me the following message: "Error generating HEX file."
My alternative solution was this.  I did a "build" only using the blink example.  Afterwards, I open the Arduino Builder, click Load Sketch / HEX and then click COM3.  This solution worked.  Although this solution is a bit slower, it still works.  Do you have any suggestions/ideas why the build and run is not working from the Code::Blocks IDE?
On another note, I am attempting to get the CB for Arduino to work on Ubuntu 12.  No luck so far but I will let you know if I have anymore luck.
chj_sullivan
Ok, pretend I'm new at this.
I downloaded the file CodeBlocks-Arduino-20130827.7z now what do I do with it? It's not an a Plugin, but it's not going to install it's self either. I see people taking about having just installed it. I though it would be a plugin for CodeBlocks... Help, I want in on the fun
Am I just getting to the wrong file?
microcat
#86
Oct 13, 2013, 04:59 am Last Edit: Oct 13, 2013, 05:04 am by microcat Reason: 1
Hi chj_sullivan,
The ".7z" extension on the file name means it has been compressed with 7-Zip.  You will need to locate, download, and install 7-Zip in order to decompress the file.  What to do next depends on what you get after the decompression.  If it is only a couple files, one having a ".exe" extension, then it has an installer.  Just run the file with that extension and a wizard will guide you through the process.  If instead you end up with hundreds of files in a dozen or more directories  folders, then this is the actual program, and you just need to  move it to a convenient location where you have read/write access. I don't remember which it is as it was a while ago that I tried it.  I should also mention that this is a complete Code::Blocks package, not just a plug-in.  Hope this helps.
chj_sullivan
Hi chj_sullivan,
microcat,
Thank you!! 8)  Been using C::B for school. Taking beginners C as par of my freshman classes, and to improve my projects, most of the class uses MSVS, C::B is much smoother and easier to use. When I saw Stanley's offering I was stoked!! Best of both worlds. Embarrassed about the .7z thing though. Doh!
Now to see if I can use my FTDI Basic..... :smiley-roll-sweat:
Swpolo
Stan -
I had the same issue and I found the cause was the file path.
I had a "-" in the path and when I removed it, the problem was solved.
"space" in the path is also a error generator.
Original path : C:\DEV_ELEC\Paul - Arduino\Programme_test\V2 - fonctionnel
=> error hex
Fixed path : C:\DEV_ELEC\Paul\Programme_test\V2_fonctionnel
=> Works
Hope my message is understandable
Paul
stanleyhuang
I remember I have fixed a similar issue in the latest version. Which version are you using?
