Topic: USING Arduino Micro (ATmega32U4) as ISP (Read 5222 times) previous topic - next topic
randomizer
Hi all,
I have a from-the-factory 328P on a breadboard. (I also have a couple seemingly unresponsive 328Ps with the Uno bootloader.) I also have an Arduino Micro (with the 32U4) with ArduinoISP loaded to it.
It's not working.
I get
Code: [Select]
avrdude: Device signature = 0xffffff [or 0x000000, sometimes]
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
and sometimes
Code: [Select]
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as FF
avrdude: safemode: efuse reads as 7
avrdude: safemode: Fuses OK
regardless of whether the 328P is connected to the SS, MI, MOSI, SK pins on the Micro board or the 10, 11, 12, 13 pins on the Micro board or nothing at all. So I'm thinking the ArduinoISP code is not set up to use the 32U4 correctly.
Or else I'm using avrdude wrong, but I get the same error when I try burn the bootloader from within the Arduino IDE, so I don't think it's that.
What should I do? Thanks!
Nick Gammon
I successfully ran my "board detector" sketch on the Micro.
Described here:
http://www.gammon.com.au/forum/?id=11633
Photo:
I connected the ICSP headers together except for the reset wire as described on the page above. That (the purple one) was plugged into D10 on the Micro.
Results (when plugged into the Uno as the target device):
Code: [Select]
Atmega chip detector.
Entered programming mode OK.
Signature = 1E 95 0F
Processor = ATmega328P
Flash memory size = 32768
LFuse = FF
HFuse = D6
EFuse = FD
Lock byte = CF
Clock calibration = 83
Bootloader in use: Yes
EEPROM preserved through erase: Yes
Watchdog timer always on: No
Bootloader is 512 bytes starting at 7E00
Bootloader:
7E00: 11 24 84 B7 14 BE 81 FF F0 D0 85 E0 80 93 81 00
7E10: 82 E0 80 93 C0 00 88 E1 80 93 C1 00 86 E0 80 93
7E20: C2 00 80 E1 80 93 C4 00 8E E0 C9 D0 25 9A 86 E0
7E30: 20 E3 3C EF 91 E0 30 93 85 00 20 93 84 00 96 BB
7E40: B0 9B FE CF 1D 9A A8 95 81 50 A9 F7 CC 24 DD 24
7E50: 88 24 83 94 B5 E0 AB 2E A1 E1 9A 2E F3 E0 BF 2E
7E60: A2 D0 81 34 61 F4 9F D0 08 2F AF D0 02 38 11 F0
7E70: 01 38 11 F4 84 E0 01 C0 83 E0 8D D0 89 C0 82 34
7E80: 11 F4 84 E1 03 C0 85 34 19 F4 85 E0 A6 D0 80 C0
7E90: 85 35 79 F4 88 D0 E8 2E FF 24 85 D0 08 2F 10 E0
7EA0: 10 2F 00 27 0E 29 1F 29 00 0F 11 1F 8E D0 68 01
7EB0: 6F C0 86 35 21 F4 84 E0 90 D0 80 E0 DE CF 84 36
7EC0: 09 F0 40 C0 70 D0 6F D0 08 2F 6D D0 80 E0 C8 16
7ED0: 80 E7 D8 06 18 F4 F6 01 B7 BE E8 95 C0 E0 D1 E0
7EE0: 62 D0 89 93 0C 17 E1 F7 F0 E0 CF 16 F0 E7 DF 06
7EF0: 18 F0 F6 01 B7 BE E8 95 68 D0 07 B6 00 FC FD CF
7F00: A6 01 A0 E0 B1 E0 2C 91 30 E0 11 96 8C 91 11 97
7F10: 90 E0 98 2F 88 27 82 2B 93 2B 12 96 FA 01 0C 01
7F20: 87 BE E8 95 11 24 4E 5F 5F 4F F1 E0 A0 38 BF 07
7F30: 51 F7 F6 01 A7 BE E8 95 07 B6 00 FC FD CF 97 BE
7F40: E8 95 26 C0 84 37 B1 F4 2E D0 2D D0 F8 2E 2B D0
7F50: 3C D0 F6 01 EF 2C 8F 01 0F 5F 1F 4F 84 91 1B D0
7F60: EA 94 F8 01 C1 F7 08 94 C1 1C D1 1C FA 94 CF 0C
7F70: D1 1C 0E C0 85 37 39 F4 28 D0 8E E1 0C D0 85 E9
7F80: 0A D0 8F E0 7A CF 81 35 11 F4 88 E0 18 D0 1D D0
7F90: 80 E1 01 D0 65 CF 98 2F 80 91 C0 00 85 FF FC CF
7FA0: 90 93 C6 00 08 95 80 91 C0 00 87 FF FC CF 80 91
7FB0: C0 00 84 FD 01 C0 A8 95 80 91 C6 00 08 95 E0 E6
7FC0: F0 E0 98 E1 90 83 80 83 08 95 ED DF 80 32 19 F0
7FD0: 88 E0 F5 DF FF CF 84 E1 DE CF 1F 93 18 2F E3 DF
7FE0: 11 50 E9 F7 F2 DF 1F 91 08 95 80 E0 E8 DF EE 27
7FF0: FF 27 09 94 FF FF FF FF FF FF FF FF FF FF 04 04
MD5 sum of bootloader = FB F4 9B 7B 59 73 7F 65 E8 D0 F8 A5 08 12 E7 9F
First 256 bytes of program memory:
0: 0C 94 35 00 0C 94 5D 00 0C 94 5D 00 0C 94 5D 00
10: 0C 94 5D 00 0C 94 5D 00 0C 94 5D 00 0C 94 5D 00
20: 0C 94 5D 00 0C 94 5D 00 0C 94 5D 00 0C 94 5D 00
30: 0C 94 5D 00 0C 94 5D 00 0C 94 5D 00 0C 94 5D 00
40: 0C 94 E4 03 0C 94 5D 00 0C 94 BC 00 0C 94 0A 01
50: 0C 94 5D 00 0C 94 5D 00 0C 94 5D 00 0C 94 5D 00
60: 0C 94 5D 00 0C 94 5D 00 76 02 11 24 1F BE CF EF
70: D8 E0 DE BF CD BF 11 E0 A0 E0 B1 E0 E0 E6 F9 E0
80: 02 C0 05 90 0D 92 AE 33 B1 07 D9 F7 11 E0 AE E3
90: B1 E0 01 C0 1D 92 A1 3F B1 07 E1 F7 10 E0 CA E6
A0: D0 E0 04 C0 22 97 FE 01 0E 94 AA 04 C8 36 D1 07
B0: C9 F7 0E 94 CC 02 0C 94 AE 04 0C 94 00 00 08 95
C0: CF 92 DF 92 EF 92 FF 92 0F 93 1F 93 06 EC 11 E0
D0: C8 01 40 E0 52 EC 61 E0 70 E0 0E 94 45 01 60 91
E0: 1E 01 70 91 1F 01 C8 01 40 E1 50 E0 0E 94 B4 03
F0: 92 E2 C9 2E 91 E0 D9 2E C8 01 B6 01 40 E1 50 E0
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Nick Gammon
Stuff about breadboard setups:
http://www.gammon.com.au/forum/?id=11637
More info:
randomizer
I don't have the wire, but I checked continuity between the Micro's ICSP header and the dedicated pins on the board--they're the same. So I hooked it up with them, and the 328P's RST connected to D10, and uploaded your sketch. All I got was the very first line--"Atmega chip detector."
One interesting thing is that I did see a faint "heartbeat" on the LED I've got connected to the 328P's pin 19 (Arduino 13), which is, of course, SCK. I did not see any such heartbeat before (when trying to use the Micro as an ISP).
Nick Gammon
That first line shows it didn't go into programming mode. Can you post a photo that clearly shows how you have it hooked up?
More info:
randomizer
My camera's not working. Sorry.
What I've got is:
MICRO          328P
5V ------------7 (Vcc) (via breadboard rail)
GND----------8 (GND) (via breadboard rail)
SCK----------19 (SCK)
MI------------18 (MISO)
MOSI----------17 (MOSI)
D10----------1 (RST) (and also 10K pull up from RST to Vcc rail)
Nick Gammon
Decoupling cap between pin 8 and pin 7?
More info:
Nick Gammon
Do you have a crystal or resonator? Or are you sure it is using the internal oscillator?
More info:
randomizer
Ah. No, there wasn't, and I don't have a 0.1µF. I did scrounge up two green-ceramic 47nFs (code 473). I put on across 7/8 and one across the power rails (capacitance adds in parallel, right?). Still just getting the first line. I tried a 2.2µF. No luck.
randomizer
WHOA! YES! I specifically ordered a "blank" chip from Virtuabotix--but I just put the 16MHz crystal into the circuit and voilà! Sorry not to have tried that earlier. Now to see if it'll actually flash the chip....
Nick Gammon
#10
Jan 29, 2013, 12:53 am Last Edit: Jan 29, 2013, 12:55 am by Nick Gammon Reason: 1
Ah yes, it's an old trick. My sketch has a clock output (pin 8 I think).  Pin 9.
More info:
randomizer
Successfully flashed the fuses--now it's using the internal oscillator! Thank you for your help. Now to what I actually want to do... set up a watch crystal asynchronously! Time to hit the datasheet.
Nick Gammon
I seem to recall someone doing that, not so long back. a 32.768 KHz crystal or some such thing. Or maybe that was as an input to a timer. One or the other.
One post I found:
http://interface.khm.de/index.php/lab/experiments/sleep_watchdog_battery/
Also: http://arduino.cc/forum/index.php/topic,957.0.html
More info:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
