Loading...
Pages: [1]   Go Down
Author Topic: TRANSISTOR  (Read 142 times)
Offline Offline
Newbie
I know nothing.
View Profile
can we amplify the voltage to hundreds of volt by using transistor from the 9v or any small voltage source  and therefore can use it for running televisions and other devices?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Televisions don't need to use high voltages any more smiley-wink
Yes, DC-DC conversion is used in many things, good example is a camera flash - the flash discharge tube needs a few hundred volts
and the usual technique is a power oscillator driving a step-up transformer, and the transformer secondary is rectified to charge
a capacitor.  Have a google around for camera flash driver circuits - there will be lots of examples I suspect.
For lower voltages DC-DC conversion often uses a boost or buck or boost-buck switch-mode circuit - avoiding needing a transformer,
but requiring a inductor.
And any convenient switching device can be used for driving these circuits, either bipolar or MOSFET.  (In the very old
days the oscillator might be electromechanical even!).
Logged
Valencia, Spain
Offline Offline
Faraday Member
View Profile
Amps multiplied by volts is a constant.
If you multiply the volts by 100 you'll get 100 times less amps - not enough for a TV.
Logged
No, I don't answer questions sent in private messages...
Offline Offline
Newbie
I know nothing.
View Profile
does it mean that if we are gaining the certain amount of volatge from transistor then we are also decreasing the current from transisitor by ceratin amount?
Logged
Valencia, Spain
Offline Offline
Faraday Member
View Profile
Yes.
Logged
Pages: [1]   Go Up
Print
Jump to:
