Loading...
Pages: [1]   Go Down
Author Topic: Countdown Timer sketch for PCD8544 using Adafruit Library  (Read 526 times)
Minnesota
Offline Offline
Newbie
Living each day byte by byte
View Profile
WWW
Just wanted to post this for anyone else who is looking for a simple countdown timer to use with this lcd.  Should be easily modifiable for use with others or to suit your specific needs.
I wanted to post this after looking all over for a simple countdown timer library or sketch and not finding one.
This is using the Adafruit library for PCD8544 https://github.com/adafruit/Adafruit-PCD8544-Nokia-5110-LCD-library
you also need the GFX library mentioned on that page https://github.com/adafruit/Adafruit-GFX-Library
Here's the sketch
Code:
This is an example sketch for a countdown timer using Nokia 5110 LCD
and adafruit library for the display
RWSDev.net
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
// pin 7 - SCE
// pin 6 - RST
// pin 5 - D/C
// pin 4 - DN
// pin 3 - SCLK
// set timer position on lcd
int xPos = 16;
int yPos = 16;
int hours = 0;
int minutes = 0;
int seconds = 5;
Adafruit_PCD8544 display = Adafruit_PCD8544(7, 6, 5, 4, 3);
void setup()   {
  display.begin();
  display.clearDisplay();   // clears the screen and buffer
  display.display();
  while (hours > 0 || minutes > 0 || seconds >= 0) {
    display.setContrast(30);
    display.setCursor(xPos, yPos);
    (hours < 10) ?display.print("0"):NULL;
    display.print(hours);
    display.print(":");
    (minutes < 10) ?display.print("0"):NULL;
    display.print(minutes);
    display.print(":");
    (seconds < 10) ?display.print("0"):NULL;
    display.print(seconds);
    display.display();
    stepDown();
void stepDown() {
    if (seconds > 0) {
      seconds -= 1;
      if (minutes > 0) {
        seconds = 59;
        minutes -= 1;
        if (hours > 0) {
          seconds = 59;
          minutes = 59;
          hours -= 1;
          trigger();
void trigger() {
  display.setTextSize(2);
  display.println("Boom");
  display.display();
Logged
Come see what we're doing: http://rwsdev.net
Offline Offline
Newbie
View Profile
Having trouble with this sketch.
error message for this line of code:  (hours < 10) ?display.print("0"):NULL;
Countdown_timer:43: error: second operand to the conditional operator is of type 'void', but the third operand is neither a throw-expression nor of type 'void'
Can you help me out?
HB
Logged
Minnesota
Offline Offline
Newbie
View Profile
WWW
Which IDE version, board, etc... are you using?
Also, if you've changed any of the code please include the code as well and I'll see if I can figure it out with you.
Jason
Logged
Offline Offline
Newbie
View Profile
I'm using Arduino 0022 IDE in combination with the Arduino nano board with AT Mega 328. I've not changed the code except for the pin numbering as I had already connected the Nokia 5110 via a logic level converter this way for another sketch, which worked alright in the said configuration.
pin setup:
// pin 12 - SCE
// pin 11 - RST
// pin 10 - D/C
// pin 9 - DN
// pin 8 - SCLK
Thanks for looking into it. I'm new at Arduino and programming for that matter and these are my first steps so please bear with me.
Henk
Logged
Minnesota
Offline Offline
Newbie
View Profile
WWW
i'm not sure but it may be a problem with the older version of the IDE you are using ... I've tested it on 1.0.1 and 1.5.2 and it works just fine.  Try one of those and let me know if that works.
Logged
Offline Offline
Newbie
View Profile
I got it working with IDE 1.5.2 but not after changing pin setting in your code. According to the standard Adafruit_PCD8544 library the pin direction are:
  Adafruit_PCD8544(int8_t SCLK, int8_t DIN, int8_t DC, int8_t CS, int8_t RST)
Thanks for helping out. I'm hoping to use part of your code in other projects.
Henk
Logged
Pages: [1]   Go Up
Print
Jump to:
