Topic: Reset pin on ATtiny84 (Read 727 times) previous topic - next topic
Ben1234
  This is my first time using an ATtiny84 and I just wanted to verify two things.
First in the attached picture is this the correct setup for the reset pin with a pushbutton? The resistor value is 10K Ohm
Secondly does anyone have a suggestion for a resistor value between on the pins and a PNP 2N3906 transistor?
Thanks in advance for your help.
Jack Christensen
(A) Yes, and
(2) I'd use 1000?, but it's probably not terribly critical.
MCP79411/12 RTC ... "One Million Ohms" ATtiny kit ... available at http://www.tindie.com/stores/JChristensen/
Ben1234
Thanks.
For the resistor is there an equation that you are supposed to use or is it just a rough value works?
Jack Christensen
Thanks.
I just go with the latter.  Don't want to load the ┬ÁC pin too much, but still want to drive the transistor to saturation. I'm sure an afternoon could be spent calculating the exact proper value, but 1K has worked well enough for me.
But just to be a little more thorough, what kind of transistor, and what will it be driving?
Ben1234
A PNP 2N3906 https://www.sparkfun.com/products/522 . It will be connected to a bunch of LEDs to turn them on and off.
Jack Christensen
That's probably a 100mA load, give or take. I'd try the 1K with one LED, measure the collector voltage, add a couple LEDs at a time. If the collector voltage doesn't get low enough to drive the LEDs bright enough, try one of those 330? guys on the transistor base instead. If that still doesn't achieve the desired results, then a different transistor might be in order.
Ben1234
The leds should not draw more than 160ma (8*20ma) so hopefully it will work. The description said up to 200ma. Do you think that there might be a problem, though?
Jack Christensen
Jack Christensen
Thanks for your help!!
Let us know if it was good help or ... otherwise XD
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
