Loading...
Pages: 1 [2]   Go Down
Author Topic: Solar panels wired to 12V batteries in parallel  (Read 537 times)
Earth
Offline Offline
Full Member
Webmaster
View Profile
WWW
2. The batteries need to be isolated to prevent them from simply discharging each other http://vandwellers.org/isolator/index.html
A isolator is required if one battery is wired to the vehicle starter and ignition to prevent you from discharging all the batteries in a worse case situation. If you run down the starter battery you can't get get the rig running and can't get home. If you have each battery on an isolator then you will have multiple batteries, and the batteries can't share the load between them. Only the battery for the vehicle starter needs to be isolated...
then i dont need the isolator cause my trailer dont move nitwit. theres no engine. oh-my-gawd. ha-ha
so, with that new information we will go with all AGMs with the current diagram. we dont need to isolate anything. right?
ps: and yes i have been sleeping above that gel one for over a year and it still works.
« Last Edit: January 29, 2013, 07:35:33 pm by TrailerTrash » Logged
Webmaster living off grid in a camper with 300watts of solar panels charging 9 absorbed glass mat 12V batteries. i own about 40 dot coms. i can read, write and debug HTML, CSS, JSON and PHP. I can understand some javascript. A++ is new to me. i thought it was a dead language. lol! A rogue planet called Nibiru is close by and will cause disasters all over earth including fireballs, earthquakes, meteors and volcanic eruptions. But i will be ready with  Project Camper
Earth
Offline Offline
Full Member
Webmaster
View Profile
WWW
my inverter has been off since the summer 5months ago. it is not used. but sitting in front of me is my 42" Sharp Aquos mocking me and motivating me. it needs 950watts to turn on. i got 600w. now what?
Logged
Earth
Offline Offline
Full Member
Webmaster
View Profile
WWW
can someone go delete all the posts that contain the word isolator. since i dont need it. thanx
or maybe i delete my thread and start over. hhhhmmm
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
