Author Topic: What can measure how much propane i have in two 20lb tanks?  (Read 385 times)
Earth
Webmaster
we were discussing this in another thread but i think it deserves its own thread. i would love to see how much propane i have left in each propane tank outside my camper on my Droid or laptop computer with my Arduino mega 2560. BUT.... it was 0 degrees outside the other morning. so the only way to do it is to weigh them separately.
« Last Edit: January 28, 2013, 08:14:23 pm by TrailerTrash » Logged
Webmaster living off grid in a camper with 300watts of solar panels charging 9 absorbed glass mat 12V batteries. i own about 40 dot coms. i can read, write and debug HTML, CSS, JSON and PHP. I can understand some javascript. A++ is new to me. i thought it was a dead language. lol! A rogue planet called Nibiru is close by and will cause disasters all over earth including fireballs, earthquakes, meteors and volcanic eruptions. But i will be ready with  Project Camper
Dee Why NSW
I suppose you could use one of those reversing cameras to check a pair of gasfuses. No need for an arduino.
Earth
Webmaster
great idea but i forgot to mention im off grid and low on power at night. can a backup camera see in the dark?
Dee Why NSW
I would imagine so. I just look over the sternrail myself. You could always install a light, secure in the knowledge that it surely doesn't have to be on for long.
Central Indiana, USA
So many projects, so little time...and money!
Most of those cameras can see infrared, so if you didn't want a light turning on to bother you when you're trying to go to sleep, you could use an IR LED as the light source.  May need to check that it will properly illuminate the target.  As Nick said, you could just turn it on intermittently, so you don't use too much power.
Earth
Webmaster
no, i need this measuring all the time. when im gone i will check it with my droid. or have it call me and wake me up. think hi tech man. plus on the same droid screen it will show all my other sensors running at http://arduino.cc/forum/index.php/topic,144152.msg1088328.html
Earth
Webmaster
i dont want to wake up and find out its 45degrees inside! i wanna know at that moment its empty.
The only adequate way to measure how much gas is still in a bottle is, I beleve, by weighing the thing, so you can use this:
 http://arduino.cc/forum/index.php/topic,18768.0.html
Earth
Webmaster
so i need two load sensors. sweet!
SW Scotland
You should not (polite for do not) need continuous monitoring.
What gas burning system could you possibly have that can consume say 10% of tank contents in under 10 minutes.  If the electronics wake-up and taking an instantaneous snapshot once every 10 minutes or so will be more than adequate.  So the whole battery system only needs to be active for say 2 seconds every 10 minutes.
Propane cylinders develop a thermal gradient as the gas is consumed so monitoring the "hot/cold" interface will give you a good assessment of content.  A simple thermal image should give you what you need and a piece of "intelligence" to assess where that interface is with respect to tank volume.
Toledo, OH
How about the simple solution.  An alarm that goes off when the temperature reaches say 55 degrees, or whatever you set as the alarm temp?  Also, as a RV owner myself, I have both tanks connected but only one turned on.  When one goes empty, there's no need to switch tanks in the middle of the cold night.  Just turn the other one on.  The next day or so I swap out the empty tank.  The only time I have both tanks on is while traveling, so the refrigerator will continue to run even if one tank runs out.
Another possible way other than a simple thermostat alarm is something that's connected to the furnace.  When the furnace tries to fire up and it can't because there's no fuel it trips some sensor which you monitor and that sets off an alarm.  But thinking about the last time my tank ran out while I was sleeping, I seem to remember the starter on my furnace clicking a bunch, and that actually woke me up.  If you have a pilot light, that may be even easier, just monitor the temp of the thermocouple.  When it's no longer hot, your pilot is out which means you're either out of fuel or you have some other type of furnace problem, which would warrant an alarm too.
Good luck and keep us updated!
Tim
Arduino Uno - Teensy 2.0 - Teensy 3.0 - Raspberry Pi Model B w/512MB RAM
My libraries: NewPing library - LCDBitmap library - toneAC library - NewTone library
This is a link in Dutch, but it translates as:
Automatic switch for gasbottles.
Once you know what to look for, you can probably find one closer to you, and for a cheaper price.
http://www.pittenspecialist.nl/index.php?page=shop.product_details&flypage=shop.flypage_xl&product_id=765&category_id=83&manufacturer_id=0&option=com_virtuemart&Itemid=26
