bethesda
Offline
Newbie
bees, sensors and remote sensing
« on: January 28, 2013, 05:34:42 pm » |
Can you give steps to clear this error so programs will again upload? I have onlu the usb cable. Have tried to clear the error by operating the reset on the board. no go. Do I need another cable to rest individual pins? wheere to buy it?
Logged
teaches science for ReSet in the inner city
bethesda
Offline
Newbie
« Reply #1 on: January 28, 2013, 05:39:08 pm » |
Can you give steps to clear this error so programs will again upload? I have only the usb cable. Have tried to clear the error by operating the reset on the board while uploading the BLINK program. no go. Please do it step by step. I'm not very experienced with the UNO. BTW... the program that preceded the error was "SleepDEMOserial"
Logged
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #2 on: January 28, 2013, 05:43:34 pm » |
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #3 on: January 28, 2013, 05:45:55 pm » |
What board? What version of the IDE? What operating system are you using? Help us out here.
Logged
bethesda
Offline
Newbie
« Reply #4 on: January 28, 2013, 08:57:23 pm » |
the board is the Arduino Uno rev 3 with no external components connected to it. IDE is 1.0.3 (I believe that is what you are referring to) OS 10.4.11
after uploading sleep software the goal was to measure sleep current of the UNO by itself to calculate the life of a battery pack, 4 ea AA rechargeables producing 4.6V at 2450maH. After the SLEEPDEMOserial upload, the next upload produced the error.
Logged
bethesda
Offline
Newbie
« Reply #5 on: January 28, 2013, 09:11:01 pm » |
Sorry... IDE :Xcode 2.5 Developer Tools for Mac OS X v10.4 (Tiger
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #6 on: January 28, 2013, 10:43:17 pm » |
Where did you connect those 4 batteries exactly? Did you measure the voltage from them?
Logged
bethesda
Offline
Newbie
« Reply #7 on: January 29, 2013, 04:56:03 pm » |
An adafruit 4-AA battery pack positive lead connected to the black lead of the mmeter set at 200ma. red mmeter lead to the red lead of the barrel power male black batterypack lead to the black lead of the barrel power male
barrel male to female power on the UNO
current was `25ma
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #8 on: January 29, 2013, 05:09:47 pm » |
That's current, not voltage.
I just wondered what voltage was coming out of your battery pack.
Can you take a photo or draw a sketch of what you just described? It was rather confusing.
Logged
bethesda
Offline
Newbie
« Reply #9 on: January 30, 2013, 10:27:39 pm » |
Sorry... Voltage was 5.26 V. measured across the connector that plugs into the UNO. battery pack is javascript:popupWindow(' http://www.adafruit.com/index.php?main_page=popup_image&pID=830').
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #10 on: January 30, 2013, 11:57:09 pm » |
calculate the life of a battery pack, 4 ea AA rechargeables producing 4.6V That's somewhat higher than you expected isn't it? Is it possible it was over 5.5V when you tested it earlier?
Logged
Anaheim CA.
Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
« Reply #11 on: January 31, 2013, 12:30:46 am » |
Also the reason why he can't reprogram the Uno... @ 4.6V / 4 = 1.15 V or a nearly discharged Ni-Cd battery and there is a fixed 1.6 - 1.8 volt regulator I/O differential which would leave about 2.5 - 2.9 V for the processor, Maybe and worse because of the poor state of the Ni-Cd's
Bob
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #12 on: January 31, 2013, 12:34:01 am » |
He actually measured 5.26V. Too high for +5V and too low for Vin.
The photo would help, hint hint ...
Logged
Ontario
Offline
God Member
« Reply #13 on: January 31, 2013, 11:10:05 am » |
You won't correctly measure the current draw from the batteries when the Arduino is also connected to, and powered by the USB cable. If it is NOT connected to the USB cable, I can suggest a possible reason why the programming step might fail...
Logged
