Author Topic: error: avrdude: stk  (Read 376 times)
bethesda
bees, sensors and remote sensing
Can you give steps to clear this error so programs will again upload? I have onlu the usb cable. Have tried to clear the error by operating the reset on the board. no go. Do I need another cable to rest individual pins? wheere to buy it?
teaches science for ReSet in the inner city
bethesda
Can you give steps to clear this error so programs will again upload? I have only the usb cable. Have tried to clear the error by operating the reset on the board while uploading the BLINK program. no go. Please do it step by step. I'm not very experienced with the UNO.
BTW... the program that preceded the error was "SleepDEMOserial"
Melbourne, Australia
Shannon Member
Lua rocks!
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
Shannon Member
Lua rocks!
What board? What version of the IDE? What operating system are you using? Help us out here.
bethesda
the board is the Arduino Uno rev 3 with no external components connected to it.
 IDE is 1.0.3 (I believe that is what you are referring to)
  OS 10.4.11
after uploading sleep software the goal was to measure  sleep current of the UNO by itself to calculate the life of a battery pack, 4 ea AA rechargeables producing 4.6V at 2450maH. After the SLEEPDEMOserial upload, the next upload produced the error.
bethesda
Sorry... IDE :Xcode 2.5 Developer Tools for
Mac OS X v10.4 (Tiger
Shannon Member
Lua rocks!
Where did you connect those 4 batteries exactly? Did you measure the voltage from them?
bethesda
An adafruit 4-AA battery pack
positive lead connected to the black lead of the mmeter set at 200ma.
red mmeter lead to the red lead of the barrel power male
black batterypack lead to the black lead of the barrel power male
barrel male to female power on the UNO
current was `25ma
Shannon Member
Lua rocks!
That's current, not voltage.
I just wondered what voltage was coming out of your battery pack.
Can you take a photo or draw a sketch of what you just described? It was rather confusing.
bethesda
Sorry... Voltage was 5.26 V. measured across the connector that plugs into the UNO. battery pack is javascript:popupWindow('http://www.adafruit.com/index.php?main_page=popup_image&pID=830').
Shannon Member
Lua rocks!
That's somewhat higher than you expected isn't it? Is it possible it was over 5.5V when you tested it earlier?
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
Also the reason why he can't reprogram the Uno... @ 4.6V / 4 = 1.15 V or a nearly discharged Ni-Cd battery and there is a fixed 1.6 - 1.8 volt regulator I/O differential which would  leave about 2.5 - 2.9 V for the processor, Maybe and worse because of the poor state of the Ni-Cd's
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Shannon Member
Lua rocks!
He actually measured 5.26V. Too high for +5V and too low for Vin.
The photo would help, hint hint ...
Ontario
You won't correctly measure the current draw from the batteries when the Arduino is also connected to, and powered by the USB cable.
If it is NOT connected to the USB cable, I can suggest a possible reason why the programming step might fail...
