Loading...
Pages: 1 [2]   Go Down
Author Topic: Simple button counter that increments by 5  (Read 273 times)
Offline Offline
Newbie
View Profile
Delta_G
The code works as i want it to, but the code is probably full of wrong code and i will clean it up when the project is complete:)
Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
I'll explain what you have.
This will show 5 when the button is pressed. NOTE it will not start at 0, even when declaired "int Counter = 0;" the reason your Serial.println().
Code:
if (CurrentSwitch == LOW)
        Counter=Counter+5;
        Serial.println(Counter); // <= This is the reason you see 5 instead of 0 because it is inside the same IF statement, however if you move
                                       // Serial.println(Counter); outside the IF statement it will start at 0, but it will show continious numbers.
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Pages: 1 [2]   Go Up
Print
Jump to:
