Loading...
Pages: [1]   Go Down
Author Topic: Can Arduino Uno Power 12v short LED strips? (new user needs help!)  (Read 470 times)
Nottingham UK
Offline Offline
Newbie
View Profile
Hi Everyone,
Im a Max/Msp user trying to graduate to Arduino and this is my first post so please be kind!  smiley
What i hope to do is power 12 led strips from my Ardurino Uno, (these are the strips, http://www.ledlightszone.co.uk/led-tape/60-flexible-led-strips-non-waterproof-72w-30pcs.html )
Each strip will only be a max of 15cm,
Is this possible or will i need some other bits and bobs?
Kind Regards,
Oli
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
You will "need some other bits and bobs"
Simplest is a part like UNL2003 or ULN2803.
Connect the + of your strips to a +12V supply, connect the - of hte strip to the output of the ULN2003.
ULN2003 Gnd connects to same Gnd that 12V supply and Arduino connect to. COM is not connected.
Arduino connects to the ULN2003 input - when input is high, output goes low, strip turns on.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Beijing
Offline Offline
Full Member
Skype name habib.derbyshire
View Profile
WWW
YOu can drive it with a transistor or MOSFET
Logged
What is man's best friend? The breadboard!
Nottingham UK
Offline Offline
Newbie
View Profile
Thanks guys I will check them out!
Regards,
Oli
Logged
Copenhagen / Denmark
Offline Offline
Edison Member
Do it !
View Profile
WWW
Check this site:
http://www.stumbleupon.com/su/1ZsVg5/genericnerd.blogspot.com/2009/05/arduino-mood-light-controller.html/
If you just want to control the RGB levels, you can skip most of the components in the lower left part of the schematic.
Logged
Switzerland
Offline Offline
Newbie
View Profile
WWW
I think these tutorials might be helpful.
Logged
Nottingham UK
Offline Offline
Newbie
View Profile
Brilliant stuff!
I now feel confident i can order a few things and get stuck in.  smiley-grin
Thanks for the input everyone,
Ill post up if/when I complete my project!
Regards,
Oli
Logged
Pages: [1]   Go Up
Print
Jump to:
