Topic: How to reset Arduino UNO without pushing reset button? (Read 4356 times) previous topic - next topic
creativen
Anybody, I would like to reset my Arduino UNO just via sending serial command, is it possible and safe for the chip?
Could it be done without pushing reset button?
Thank you ..
retrolefty
Thank you ..
Sure, just learn about using the watch dog timer (WDT), your sketch upon receiving the magic serial command could just activate the WDT which will cause a reset and start you sketch from it's start.
Lefty
Jack Christensen
Yes and yes. When the command is recognized from the serial interface, set the watchdog timer for a short interval (I think 16ms is the shortest), and enter a spin loop. Search the forum for specifics, this gets discussed with fair regularity.
retrolefty
Just be sure your arduino board is one that has a WDT friendly bootloader such as the current UNO, as older and current mega boards for example will 'brick' with short WDT interrupts, requiring you to reburn the bootloader to recover.
Lefty
PeterH
In most cases you can do it just by closing and reopening the serial port. But why do you want to reset it?
I only provide help via the forum - please do not contact me for private consultancy.
creativen
I just would like to take control my Arduino without touching it, it's cool if I can reset from distant afar.
PaulS
The question is why? Opening and closing the serial port resets the Arduino, unless you've modified. That seems sufficient to me.
PeterH
If being 'cool' is your only reason then I don't see any point. It's not as if you will get to see those LEDs flash briefly as it resets. And what other reason would you have for wanting to reset it?
tuxduino
liudr
Lefty
So how to software reboot MEGA then?
retrolefty
Lefty
Use external hardware components (555 pulse generator for example) to generate a reset pulse wired to the avr reset pin.
Or find a upgraded bootloader hex file that does handle WDT correctly for the mega board and burn that into the chip before using the WDT generated reset method.
Lefty
draythomp
#11
Jan 29, 2013, 04:16 pm Last Edit: Jan 29, 2013, 04:27 pm by draythomp Reason: 1
Depending on exactly what you want to do, use a call to location zero as in:
void(* resetFunc) (void) = 0; //declare reset function @ address 0
Or, if you want something more watchdog 'timerish', use the code I worked out to do this.  I wanted to simulate a watchdog and not use up any of the other timers.  It's at: http://www.desert-home.com/2011/10/2560-board-is-not-so-stupid-anymore.html
Trying to keep my house under control http://www.desert-home.com/
liudr
Lefty,
By upgraded bootloader are you referring to optiboot developed by westfw?
liudr
Thanks. I know of the location zero but also vaguely remember people mentioning that just the execution is reset and other things aren't. Could you give me some hint on what does and doesn't reset by calling zero?
BTW, your home page temperature scale is in DegF, right? Does it every go near 150F as the max scale is set there? Horrible heat.
retrolefty
#14
Jan 29, 2013, 05:40 pm Last Edit: Jan 29, 2013, 05:42 pm by retrolefty Reason: 1
Lefty,
Depends on the type of mega board you are talking about. There is a optiboot avalible for the mega1280 board but westfw already stated the optiboot will never work with a mega2560 board. However there is a upgraded/fixed mega2560 bootloader avalible that works with the WDT correctly, but at the moment I can't steer you to it's location as I don't own a mega2560 board I never bothered to download a fixed bootloader for it.
If you do want or need a mega1280 optiboot.hex file I would be glad to post it here for you?
PS: A simple jump to 0 to restart a sketch doesn't place any of the AVR hardware registers to their true default reset condition, which may or may not to a big deal, so is rarely recommended as a reliable method to use.
Lefty
