Topic: Hyperions effect to arudino ? (Read 499 times) previous topic - next topic
nox1989
Hi!
I have a raspberry pi with Hyperion installed so I can control a LED-strip with my phone using the Hyperion app.
So I'm thinking about replacing raspberry pi with an arduino uno, but I want the same effect as I have on the raspberry pi, like a lot of diffrent  "mood blobs" and like "Rainbow swirl" and "Knight rider" and so on.
So my question is:  Is there any written code for the effects thats on hyperion in arduino C-code ? Or can you convert the Hyperion's .py and .json file to get C-code ?
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
nox1989
Sure!
Here is the code in mood-blobs.py
Code: [Select]
import hyperion
import time
import colorsys
import math
# Get the parameters
rotationTime = float(hyperion.args.get('rotationTime', 20.0))
color = hyperion.args.get('color', (0,0,255))
hueChange = float(hyperion.args.get('hueChange', 60.0))
blobs = int(hyperion.args.get('blobs', 5))
reverse = bool(hyperion.args.get('reverse', False))
baseColorChange = bool(hyperion.args.get('baseChange', False))
baseColorRangeLeft = float(hyperion.args.get('baseColorRangeLeft',0.0))   # Degree
baseColorRangeRight = float(hyperion.args.get('baseColorRangeRight',360.0))   # Degree
baseColorChangeRate = float(hyperion.args.get('baseColorChangeRate',10.0))   # Seconds for one Degree
# switch baseColor change off if left and right are too close together to see a difference in color
if (baseColorRangeRight > baseColorRangeLeft and (baseColorRangeRight - baseColorRangeLeft) < 10) or \
   (baseColorRangeLeft > baseColorRangeRight and ((baseColorRangeRight + 360) - baseColorRangeLeft) < 10):
   baseColorChange = False
# 360 -> 1
fullColorWheelAvailable = (baseColorRangeRight % 360) == (baseColorRangeLeft % 360)
baseColorChangeIncreaseValue = 1.0 / 360.0 # 1 degree
hueChange /= 360.0
baseColorRangeLeft = (baseColorRangeLeft / 360.0)
baseColorRangeRight = (baseColorRangeRight / 360.0)
# Check parameters
rotationTime = max(0.1, rotationTime)
hueChange = max(0.0, min(abs(hueChange), .5))
blobs = max(1, blobs)
baseColorChangeRate = max(0, baseColorChangeRate) # > 0
# Calculate the color data
baseHsv = colorsys.rgb_to_hsv(color[0]/255.0, color[1]/255.0, color[2]/255.0)
colorData = bytearray()
for i in range(hyperion.ledCount):
hue = (baseHsv[0] + hueChange * math.sin(2*math.pi * i / hyperion.ledCount)) % 1.0
rgb = colorsys.hsv_to_rgb(hue, baseHsv[1], baseHsv[2])
colorData += bytearray((int(255*rgb[0]), int(255*rgb[1]), int(255*rgb[2])))
# Calculate the increments
sleepTime = 0.1
amplitudePhaseIncrement = blobs * math.pi * sleepTime / rotationTime
colorDataIncrement = 3
baseColorChangeRate /= sleepTime
# Switch direction if needed
if reverse:
amplitudePhaseIncrement = -amplitudePhaseIncrement
colorDataIncrement = -colorDataIncrement
# create a Array for the colors
colors = bytearray(hyperion.ledCount * (0,0,0))
# Start the write data loop
amplitudePhase = 0.0
rotateColors = False
baseColorChangeStepCount = 0
baseHSVValue = baseHsv[0]
numberOfRotates = 0
while not hyperion.abort():
   # move the basecolor
   if baseColorChange:
       # every baseColorChangeRate seconds
       if baseColorChangeStepCount >= baseColorChangeRate:
           # cyclic increment when the full colorwheel is available, move up and down otherwise
           if fullColorWheelAvailable:
               baseHSVValue = (baseHSVValue + baseColorChangeIncreaseValue) % baseColorRangeRight
           else:
               # switch increment direction if baseHSV <= left or baseHSV >= right
               if baseColorChangeIncreaseValue < 0 and baseHSVValue > baseColorRangeLeft and (baseHSVValue + baseColorChangeIncreaseValue) <= baseColorRangeLeft:
                   baseColorChangeIncreaseValue = abs(baseColorChangeIncreaseValue)
               elif baseColorChangeIncreaseValue > 0 and baseHSVValue < baseColorRangeRight and (baseHSVValue + baseColorChangeIncreaseValue)  >= baseColorRangeRight :
                   baseColorChangeIncreaseValue = -abs(baseColorChangeIncreaseValue)
               baseHSVValue = (baseHSVValue + baseColorChangeIncreaseValue) % 1.0
           # update color values
               hue = (baseHSVValue + hueChange * math.sin(2*math.pi * i / hyperion.ledCount)) % 1.0
           # set correct rotation after reinitialisation of the array
           colorData = colorData[-colorDataIncrement*numberOfRotates:] + colorData[:-colorDataIncrement*numberOfRotates]
       baseColorChangeStepCount += 1
   # Calculate new colors
       amplitude = max(0.0, math.sin(-amplitudePhase + 2*math.pi * blobs * i / hyperion.ledCount))
       colors[3*i+0] = int(colorData[3*i+0] * amplitude)
       colors[3*i+1] = int(colorData[3*i+1] * amplitude)
       colors[3*i+2] = int(colorData[3*i+2] * amplitude)
   # set colors
   hyperion.setColor(colors)
   # increment the phase
   amplitudePhase = (amplitudePhase + amplitudePhaseIncrement) % (2*math.pi)
   if rotateColors:
       colorData = colorData[-colorDataIncrement:] + colorData[:-colorDataIncrement]
       numberOfRotates = (numberOfRotates +  1) % hyperion.ledCount
   rotateColors = not rotateColors
   # sleep for a while
   time.sleep(sleepTime)
And here is one of the .json file:
Code: [Select]
"name" : "Full color mood blobs",
"script" : "mood-blobs.py",
"args" :
"rotationTime" : 60.0,
"color" : [0,0,255],
"hueChange" : 30.0,
"blobs" : 5,
"reverse" : false,
"baseChange" : true,
"baseColorRangeLeft" : 0,
"baseColorRangeRight" : 360,
"baseColorChangeRate" : 0.2
Grumpy_Mike
That is not proper Python code the indentation is totally missing so it is meaningless.
Converting between Python and C is relitave easy but not with no indentation.
PaulRB
Worse! Some is missing and some isn't. If it was all missing, it could be the result of a cut & paste error. But partial indentation just tells you the source code is corrupted.
