Topic: Ethernet Shield + DHCP (Read 2527 times) previous topic - next topic
Paradigm
Dear All,
              Anyone tried the Ethernet shield connecting using DHCP? Got the code from http://gkaindl.com/software/arduino-ethernet/dhcp but cannot comply with my Uno R3 and Ethernet R3. Dont know whether its because of version problem. Run the code from the example
//  Copyright (C) 2010 Georg Kaindl
//  http://gkaindl.com
//  This file is part of Arduino EthernetDHCP.
//  EthernetDHCP is free software: you can redistribute it and/or modify
//  it under the terms of the GNU Lesser General Public License as
//  published by the Free Software Foundation, either version 3 of
//  the License, or (at your option) any later version.
//  EthernetDHCP is distributed in the hope that it will be useful,
//  but WITHOUT ANY WARRANTY; without even the implied warranty of
//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
//  GNU Lesser General Public License for more details.
//  You should have received a copy of the GNU Lesser General Public
//  License along with EthernetDHCP. If not, see
//  <http://www.gnu.org/licenses/>.
//  Illustrates how to use EthernetDHCP in polling (non-blocking)
//  mode.
#if defined(ARDUINO) && ARDUINO > 18
#include <SPI.h>
#endif
#include <Ethernet.h>
#include <EthernetDHCP.h>
const char* ip_to_str(const uint8_t*);
  // Initiate a DHCP session. The argument is the MAC (hardware) address that
  // you want your Ethernet shield to use. The second argument enables polling
  // mode, which means that this call will not block like in the
  // SynchronousDHCP example, but will return immediately.
  // Within your loop(), you can then poll the DHCP library for its status,
  // finding out its state, so that you can tell when a lease has been
  // obtained. You can even find out when the library is in the process of
  // renewing your lease.
  EthernetDHCP.begin(mac, 1);
  static DhcpState prevState = DhcpStateNone;
  static unsigned long prevTime = 0;
  // poll() queries the DHCP library for its current state (all possible values
  // are shown in the switch statement below). This way, you can find out if a
  // lease has been obtained or is in the process of being renewed, without
  // blocking your sketch. Therefore, you could display an error message or
  // something if a lease cannot be obtained within reasonable time.
  // Also, poll() will actually run the DHCP module, just like maintain(), so
  // you should call either of these two methods at least once within your
  // loop() section, or you risk losing your DHCP lease when it expires!
  DhcpState state = EthernetDHCP.poll();
  if (prevState != state) {
    Serial.println();
    switch (state) {
      case DhcpStateDiscovering:
        Serial.print("Discovering servers.");
        break;
      case DhcpStateRequesting:
        Serial.print("Requesting lease.");
        break;
      case DhcpStateRenewing:
        Serial.print("Renewing lease.");
        break;
      case DhcpStateLeased: {
        Serial.println("Obtained lease!");
        // Since we're here, it means that we now have a DHCP lease, so we
        // print out some information.
        const byte* ipAddr = EthernetDHCP.ipAddress();
        const byte* gatewayAddr = EthernetDHCP.gatewayIpAddress();
        const byte* dnsAddr = EthernetDHCP.dnsIpAddress();
        Serial.print("My IP address is ");
        Serial.println(ip_to_str(ipAddr));
        Serial.print("Gateway IP address is ");
        Serial.println(ip_to_str(gatewayAddr));
        Serial.print("DNS IP address is ");
        Serial.println(ip_to_str(dnsAddr));
        Serial.println();
        break;
  } else if (state != DhcpStateLeased && millis() - prevTime > 300) {
     prevTime = millis();
     Serial.print('.');
  prevState = state;
// Just a utility function to nicely format an IP address.
const char* ip_to_str(const uint8_t* ipAddr)
  static char buf[16];
  sprintf(buf, "%d.%d.%d.%d\0", ipAddr[0], ipAddr[1], ipAddr[2], ipAddr[3]);
  return buf;
Its says that the wiring.h in the EthernetDHCP.cpp is missing. Which I dont know where to get one. Anyone had try this code before or had working DHCP code to share?
Thanks a lot
SurferTim
This works for me with w5100 and IDE v1.0.1 or later.
#include <SPI.h>
  // disable SD SPI if one in the slot
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Serial.print("Starting ethernet...");
  if(!Ethernet.begin(mac)) Serial.println("failed");
  else Serial.println(Ethernet.localIP());
PaulS
DHCP is supported by core libraries in 1.0+. Get rid of the pre-1.0 library you downloaded.
Paradigm
Hi Pauls,
Are you referring to the Lib folder that is in my 1.0.1? As attached thats all my folders
SurferTim
Yes, and it works good!  :)
PaulS
No. In your initial post, you said you downloaded a library that was not needed. You need to find where you put it, and get rid of it.
