Dear All,
Anyone tried the Ethernet shield connecting using DHCP? Got the code from
http://gkaindl.com/software/arduino-ethernet/dhcp but cannot comply with my Uno R3 and Ethernet R3. Dont know whether its because of version problem. Run the code from the example
// Copyright (C) 2010 Georg Kaindl
// http://gkaindl.com
// This file is part of Arduino EthernetDHCP.
// EthernetDHCP is free software: you can redistribute it and/or modify
// it under the terms of the GNU Lesser General Public License as
// published by the Free Software Foundation, either version 3 of
// the License, or (at your option) any later version.
// EthernetDHCP is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with EthernetDHCP. If not, see
// <http://www.gnu.org/licenses/>.
// Illustrates how to use EthernetDHCP in polling (non-blocking)
// mode.
#if defined(ARDUINO) && ARDUINO > 18
#include <SPI.h>
#endif
#include <Ethernet.h>
#include <EthernetDHCP.h>
const char* ip_to_str(const uint8_t*);
// Initiate a DHCP session. The argument is the MAC (hardware) address that
// you want your Ethernet shield to use. The second argument enables polling
// mode, which means that this call will not block like in the
// SynchronousDHCP example, but will return immediately.
// Within your loop(), you can then poll the DHCP library for its status,
// finding out its state, so that you can tell when a lease has been
// obtained. You can even find out when the library is in the process of
// renewing your lease.
EthernetDHCP.begin(mac, 1);
static DhcpState prevState = DhcpStateNone;
static unsigned long prevTime = 0;
// poll() queries the DHCP library for its current state (all possible values
// are shown in the switch statement below). This way, you can find out if a
// lease has been obtained or is in the process of being renewed, without
// blocking your sketch. Therefore, you could display an error message or
// something if a lease cannot be obtained within reasonable time.
// Also, poll() will actually run the DHCP module, just like maintain(), so
// you should call either of these two methods at least once within your
// loop() section, or you risk losing your DHCP lease when it expires!
DhcpState state = EthernetDHCP.poll();
if (prevState != state) {
Serial.println();
switch (state) {
case DhcpStateDiscovering:
Serial.print("Discovering servers.");
break;
case DhcpStateRequesting:
Serial.print("Requesting lease.");
break;
case DhcpStateRenewing:
Serial.print("Renewing lease.");
break;
case DhcpStateLeased: {
Serial.println("Obtained lease!");
// Since we're here, it means that we now have a DHCP lease, so we
// print out some information.
const byte* ipAddr = EthernetDHCP.ipAddress();
const byte* gatewayAddr = EthernetDHCP.gatewayIpAddress();
const byte* dnsAddr = EthernetDHCP.dnsIpAddress();
Serial.print("My IP address is ");
Serial.println(ip_to_str(ipAddr));
Serial.print("Gateway IP address is ");
Serial.println(ip_to_str(gatewayAddr));
Serial.print("DNS IP address is ");
Serial.println(ip_to_str(dnsAddr));
Serial.println();
break;
} else if (state != DhcpStateLeased && millis() - prevTime > 300) {
prevTime = millis();
Serial.print('.');
prevState = state;
// Just a utility function to nicely format an IP address.
const char* ip_to_str(const uint8_t* ipAddr)
static char buf[16];
sprintf(buf, "%d.%d.%d.%d\0", ipAddr[0], ipAddr[1], ipAddr[2], ipAddr[3]);
return buf;
Its says that the wiring.h in the EthernetDHCP.cpp is missing. Which I dont know where to get one. Anyone had try this code before or had working DHCP code to share?
Thanks a lot
