Loading...
Pages: [1]   Go Down
Author Topic: Where can I find gray LCD (like the one in a calculator)  (Read 203 times)
Israel
Offline Offline
Full Member
View Profile
I am looking for a very cheap LCD like the ones install in calculators or something like this.
What are they called? Can they be connected easily to an Arduino?
Logged
Beijing
Offline Offline
Full Member
Skype name habib.derbyshire
View Profile
WWW
You mean a seven segment LCD display like this:
http://il.farnell.com/productimages/nio/standard/3767492.jpg
Logged
What is man's best friend? The breadboard!
NE PA
Offline Offline
Full Member
View Profile
WWW
Try searching for "LCD" on adafruit.com or sparkfun.com or "lcd arduino" on ebay. Just make sure it is Hitachi HD44780 compatible so it'll be easily connected to the arduino.
Logged
Israel
Offline Offline
Full Member
View Profile
All I can come up with are the LED 7 segment type (1,2,3 or 4 digits)...
Logged
Beijing
Offline Offline
Full Member
View Profile
WWW
Like this?
http://www.ebay.com/itm/LCD5663R-25H-IEE-Seven-Segment-Numeric-LCD-Display-NEW-2-75-x7-8-/370290491980?pt=LH_DefaultDomain_0&hash=item563708824c
Logged
Washington
Offline Offline
God Member
Firefox & Arduino rocks
View Profile
http://www.ebay.com/itm/8-DIGITS-7-SEGMENT-LCD-DISPLAYS-GLASS-2-PCS-/320778989149?pt=LH_DefaultDomain_0&hash=item4aafeaee5d
They are not really easy to interface. They have loads of (possibly multiplexed) lines.
You will need to expand the output ports or get a controller IC.
Logged
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
Offline Offline
Edison Member
View Profile
Quote
From a calculator?
I buy cheap calculators from Walmart and take them apart. They go for about $1 each.
The issue with those types of calculators is that the ribbon is not solder-able. They are instead taped to the pcb. So your own option is to sand away the paint and then solder fine copper wires to the traces on the pcb.
But otherwise it works like a charm.
You can reuse the keypads + casing too.
Logged
Pages: [1]   Go Up
Print
Jump to:
