Singapore
Offline
Newbie
« on: January 29, 2013, 12:35:58 pm » |
Hi Arduino,
I am Xavier, a student from Singapore. I am working on a project which requires a controller circuit that could accept input from a capactive touch sensor and output via USB to computer. In short, to build an external mouse touch pad.
The capacitive touch sensor is a pcb board with X and Y rows of contact points.
I would then use a program to intepret the data from the controller and acquire the position of the finger in real time.
If possible, please kindly suggest the most suitable controller circuit for this project and procedure in purchasing it.
Logged
Malaysia
Offline
Sr. Member
« Reply #1 on: January 29, 2013, 12:44:41 pm » |
well , i think you need to use a due or leonardo. couse it can mimic a peripheral such as mouse and keyboard.... the way you program it well, i cant suggest to you anything due to i have no experience with it ....
Logged
Singapore
Offline
Newbie
« Reply #2 on: January 29, 2013, 12:50:46 pm » |
Thanks for sharing, previously I was lookin at "UNO" but not sure whether it can handle multiple X - Y axis of contacts points simultaneously. Any suggestion ?
Logged
Malaysia
Offline
Sr. Member
« Reply #3 on: January 29, 2013, 12:58:06 pm » |
urm as im not mistaken any board that have analog input can make do. let me see if i could find a page to help you btw its 2 am hows singapore?
Logged
Malaysia
Offline
Sr. Member
« Reply #4 on: January 29, 2013, 01:16:47 pm » |
Logged
Singapore
Offline
Newbie
« Reply #5 on: January 29, 2013, 02:34:08 pm » |
Really appreciate your help! I was at dfrobot earlier too, but because it is a proj, it would be better if I could only use arduino and the rest of the parts DIY.
Singapore just had election recently, everything is pretty normal i guess. Hows msia? U staying at KL ?
Btw, for parts on sale at dfrobot, I dont understand the centre part of the connector that connect arduino and keypad together. Is tat a converter? Can I replicate it on my own easily ?
Thanks in advance!
Logged
Singapore
Offline
Newbie
« Reply #7 on: January 30, 2013, 08:48:42 am » |
I found the schematic, my bad. thanks!
Logged
Singapore
Offline
Newbie
« Reply #8 on: January 30, 2013, 08:52:56 am » |
Do u know whether Arduino board used is 'UNO' ?
Logged
Malaysia
Offline
Sr. Member
« Reply #9 on: January 30, 2013, 11:12:49 am » |
technically if you need to use the capasitive touch sensor for any other project then any board will do. but since your making it to be an external touch pad for a comp then you need a protocol that able to mimic the functionality of a touch pad. basically your making a digitizer try look it up too
Logged
