Loading...
Pages: [1] 2   Go Down
Author Topic: to many arguments to function  (Read 286 times)
Beijing
Offline Offline
Full Member
Skype name habib.derbyshire
View Profile
WWW
Hi all! I was writing some Arduino seven seg code, and it wouldn't compile, even though there was nothing wrong with the code.
Code:
void sevenseg(int val){
  switch(val){
    case'0': zero();
    case'1': one();
    case'2': two();
    case'3': three();
    case'4': four();
    case'5': five();
    case'6': six();
    case'7': seven();
    case'8': eight();
    case'9': nine();
the error message:
Quote
/sevenseg.h: In function 'void setup()':
sevenseg.h:262: error: too many arguments to function 'void sevenseg(int)'
sketch_jan29a:13: error: at this point in file
Can anyone please tell me what the problem is?
Thanks
Habib
Logged
What is man's best friend? The breadboard!
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Sure. The function expects one argument. You are calling it with more than one. Don't do that.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
The problem is you didn't show us the code (there's a big clue here - "In function 'void setup()': ")
And what PaulS said.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Beijing
Offline Offline
Full Member
View Profile
WWW
All right, this is the full code:
Code:
#include"sevenseg.h"
int val=0;
void setup(){
  sevensegpins(13, 12, 11, 10, 9, 8, 7);
  common_cathode(true);
void loop(){
  val=(analogRead(0));
  val=map(val, 0, 1023, 0, 9);
  sevenseg(val);
and also
Code:
#include<Arduino.h>
int pin_a;
int pin_b;
int pin_c;
int pin_d;
int pin_e;
int pin_f;
int pin_g;
int ON;
int OFF;
void sevensegpins(int a, int b, int c, int d, int e, int f, int g){
  pin_a=a;
  pin_b=b;
  pin_c=c;
  pin_d=d;
  pin_e=e;
  pin_f=f;
  pin_g=g;
  pinMode(pin_a, OUTPUT);
  pinMode(pin_b, OUTPUT);
  pinMode(pin_c, OUTPUT);
  pinMode(pin_d, OUTPUT);
  pinMode(pin_e, OUTPUT);
  pinMode(pin_f, OUTPUT);
  pinMode(pin_g, OUTPUT);
void common_cathode(boolean cathode){
  if(cathode==true){
    ON=HIGH;
    OFF=LOW;
  else{
    ON=LOW;
    OFF=HIGH;
void clearall(){
  digitalWrite(pin_a, OFF);
  digitalWrite(pin_b, OFF);
  digitalWrite(pin_c, OFF);
  digitalWrite(pin_d, OFF);
  digitalWrite(pin_e, OFF);
  digitalWrite(pin_f, OFF);
  digitalWrite(pin_g, OFF);
void zero(){
  clearall();
  digitalWrite(pin_a, ON);
  digitalWrite(pin_d, ON);
  digitalWrite(pin_f, ON);
  digitalWrite(pin_e, ON);
  digitalWrite(pin_b, ON);
  digitalWrite(pin_c, ON);
void one(){
  clearall();
void two(){
  clearall();
  digitalWrite(pin_g, ON);
void three(){
  clearall();
void four(){
  clearall();
void five(){
  clearall();
void six(){
  clearall();
void seven(){
  clearall();
void eight(){
  clearall();
void nine(){
  clearall();
void lettera(){
  clearall();
void letterb(){
  clearall();
void letterB(){
  clearall();
void letterc(){
  clearall();
void letterC(){
  clearall();
void letterd(){
  clearall();
void letterD(){
  clearall();
void lettere(){
void letterE(){
  clearall();
void letterf(){
  clearall();
void letterh(){
  clearall();
void letterH(){
  clearall();
void letterl(){
  clearall();
void letterL(){
  clearall();
void letterp(){
  clearall();
void letterq(){
void letters(){
  clearall();
void letteru(){
  clearall();
  switch(val){
    case'0': zero();
    case'1': one();
    case'2': two();
    case'3': three();
    case'4': four();
    case'5': five();
    case'6': six();
    case'7': seven();
    case'8': eight();
    case'9': nine();
Logged
Beijing
Offline Offline
Full Member
View Profile
WWW
PS it used to compile
Logged
0
Offline Offline
God Member
Get Bitlash: http://bitlash.net
View Profile
I don't know if this is your bug or not, but attempting to reassign a system-provided define like ON or OFF like this is creative but not going to work:
Code:
  if(cathode==true){
    ON=HIGH;
    OFF=LOW;
  else{
    ON=LOW;
    OFF=HIGH;
-br
Edit: Never mind.  I was mistaken in assuming the ON and OFF were system defines.  My bad.
« Last Edit: January 29, 2013, 10:14:21 am by billroy » Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
I'd suggest the code you posted is not the code you're trying to compile.
Here's the error message I got:
Quote
Binary sketch size: 2436 bytes (of a 14336 byte maximum)
(compiled for 168 on IDE 1.0)
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
Why not?
Logged
0
Offline Offline
God Member
View Profile
I had myself confused that ON was a #define.  More coffee...
-br
Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
You dont need to have,
Quote
there is an easier way to get your LEDs to light up, but if it compiles like that and thats what you want to use, then go for it.
Alternative:
just use an array,
0b00000000 = all off
0b00101010  = something on
0b00010101 = something else on
0b11111111 = all on
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Beijing
Offline Offline
Full Member
View Profile
WWW
Hey all this code compiled in IDE 1.0 but did not compile in Arduino ERW. I was using ERW...Sorry for the time.
Logged
Beijing
Offline Offline
Full Member
View Profile
WWW
@HazerdousMind Thank you I knew that but this was old code I was going through, copy and pasting it
Thanks anyway!
Habib
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Code:
  sevenseg(val);
Code:
  switch(val){
    case'0': zero();
    case'1': one();
    case'2': two();
Your code will not work - lose the quotes.
Logged
Beijing
Offline Offline
Full Member
View Profile
WWW
I know... But why not? It used to.
Logged
Offline Offline
Sr. Member
View Profile
'0' is ASCII character 0, not the integer 0. ASCII character 0 is actually decimal 48.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
