Topic: to many arguments to function (Read 3196 times) previous topic - next topic
arduinohabib
Hi all! I was writing some Arduino seven seg code, and it wouldn't compile, even though there was nothing wrong with the code.
void sevenseg(int val){
 switch(val){
   case'0': zero();
   break;
   case'1': one();
   break;
   case'2': two();
   break;
   case'3': three();
   break;
   case'4': four();
   break;
   case'5': five();
   break;
   case'6': six();
   break;
   case'7': seven();
   break;
   case'8': eight();
   break;
   case'9': nine();
   break;
the error message:
/sevenseg.h: In function 'void setup()':
sevenseg.h:262: error: too many arguments to function 'void sevenseg(int)'
sketch_jan29a:13: error: at this point in file
Can anyone please tell me what the problem is?
Thanks
Habib
What is man's best friend? The breadboard!
PaulS
Sure. The function expects one argument. You are calling it with more than one. Don't do that.
AWOL
The problem is you didn't show us the code (there's a big clue here - "In function 'void setup()': ")
And what PaulS said.
arduinohabib
All right, this is the full code:
#include"sevenseg.h"
int val=0;
void setup(){
  sevensegpins(13, 12, 11, 10, 9, 8, 7);
  common_cathode(true);
void loop(){
  val=(analogRead(0));
  val=map(val, 0, 1023, 0, 9);
  sevenseg(val);
and also
#include<Arduino.h>
int pin_a;
int pin_b;
int pin_c;
int pin_d;
int pin_e;
int pin_f;
int pin_g;
int ON;
int OFF;
void sevensegpins(int a, int b, int c, int d, int e, int f, int g){
  pin_a=a;
  pin_b=b;
  pin_c=c;
  pin_d=d;
  pin_e=e;
  pin_f=f;
  pin_g=g;
  pinMode(pin_a, OUTPUT);
  pinMode(pin_b, OUTPUT);
  pinMode(pin_c, OUTPUT);
  pinMode(pin_d, OUTPUT);
  pinMode(pin_e, OUTPUT);
  pinMode(pin_f, OUTPUT);
  pinMode(pin_g, OUTPUT);
void common_cathode(boolean cathode){
  if(cathode==true){
    ON=HIGH;
    OFF=LOW;
  else{
    ON=LOW;
    OFF=HIGH;
void clearall(){
  digitalWrite(pin_a, OFF);
  digitalWrite(pin_b, OFF);
  digitalWrite(pin_c, OFF);
  digitalWrite(pin_d, OFF);
  digitalWrite(pin_e, OFF);
  digitalWrite(pin_f, OFF);
  digitalWrite(pin_g, OFF);
void zero(){
  clearall();
  digitalWrite(pin_a, ON);
  digitalWrite(pin_d, ON);
  digitalWrite(pin_f, ON);
  digitalWrite(pin_e, ON);
  digitalWrite(pin_b, ON);
  digitalWrite(pin_c, ON);
void one(){
  clearall();
void two(){
  clearall();
  digitalWrite(pin_g, ON);
void three(){
  clearall();
void four(){
  clearall();
void five(){
  clearall();
void six(){
  clearall();
void seven(){
  clearall();
void eight(){
  clearall();
void nine(){
  clearall();
void lettera(){
  clearall();
void letterb(){
  clearall();
void letterB(){
  clearall();
void letterc(){
  clearall();
void letterC(){
  clearall();
void letterd(){
  clearall();
void letterD(){
  clearall();
void lettere(){
void letterE(){
  clearall();
void letterf(){
  clearall();
void letterh(){
  clearall();
void letterH(){
  clearall();
void letterl(){
  clearall();
void letterL(){
  clearall();
void letterp(){
  clearall();
void letterq(){
void letters(){
  clearall();
void letteru(){
  clearall();
  switch(val){
    case'0': zero();
    break;
    case'1': one();
    break;
    case'2': two();
    break;
    case'3': three();
    break;
    case'4': four();
    break;
    case'5': five();
    break;
    case'6': six();
    break;
    case'7': seven();
    break;
    case'8': eight();
    break;
    case'9': nine();
    break;
arduinohabib
billroy
#5
Jan 29, 2013, 04:12 pm Last Edit: Jan 29, 2013, 04:14 pm by billroy Reason: 1
I don't know if this is your bug or not, but attempting to reassign a system-provided define like ON or OFF like this is creative but not going to work:
 if(cathode==true){
   ON=HIGH;
   OFF=LOW;
 else{
   ON=LOW;
   OFF=HIGH;
-br
Edit: Never mind.  I was mistaken in assuming the ON and OFF were system defines.  My bad.
AWOL
I'd suggest the code you posted is not the code you're trying to compile.
Here's the error message I got:
Binary sketch size: 2436 bytes (of a 14336 byte maximum)
(compiled for 168 on IDE 1.0)
AWOL
Why not?
billroy
I had myself confused that ON was a #define.  More coffee...
-br
HazardsMind
You dont need to have,
there is an easier way to get your LEDs to light up, but if it compiles like that and thats what you want to use, then go for it.
Alternative:
just use an array,
0b00000000 = all off
0b00101010  = something on
0b00010101 = something else on
0b11111111 = all on
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
arduinohabib
Hey all this code compiled in IDE 1.0 but did not compile in Arduino ERW. I was using ERW...Sorry for the time.
arduinohabib
@HazerdousMind Thank you I knew that but this was old code I was going through, copy and pasting it
Thanks anyway!
Habib
AWOL
 sevenseg(val);
 switch(val){
   case'0': zero();
   break;
   case'1': one();
   break;
   case'2': two();
Your code will not work - lose the quotes.
arduinohabib
I know... But why not? It used to.
KeithRB
'0' is ASCII character 0, not the integer 0. ASCII character 0 is actually decimal 48.
