Loading...
Pages: 1 [2]   Go Down
Author Topic: Alarma para moto...  (Read 1148 times)
0 Members and 2 Guests are viewing this topic.
Offline Offline
Newbie
View Profile
Hola de nuevo!!
Aqui va el codigo:
Quote
  _____       .__  __         .__
_/ ____\______|__|/  |________|__| ____    ____
\   __\\_  __ \  \   __\___   /  |/    \  / ___\
 |  |   |  | \/  ||  |  /    /|  |   |  \/ /_/  >
 |__|   |__|  |__||__| /_____ \__|___|  /\___  /
                             \/       \//_____/
Example      Sabotage Detection
Autor        Stefan Hermann
Date         5.12.2011
int myState=0;
int sirenaPin=9;
int greenLedPin=11;
int redLedPin=7;
int blueLedPin=3;
int buttonPin=2;
int potPin=3;
int accZPin=0;
int accYPin=1;
int accXPin=2;
int startAccZ;
int startAccY;
int startAccX;
void setup(){
  pinMode(sirenaPin,OUTPUT);
  pinMode(greenLedPin,OUTPUT);
  pinMode(redLedPin,OUTPUT);
  pinMode(blueLedPin,OUTPUT);
  pinMode(buttonPin,INPUT);
  startAccZ=analogRead(accZPin);
  startAccY=analogRead(accYPin);
  startAccX=analogRead(accXPin);
void alertBlinking(){
  digitalWrite(sirenaPin,HIGH);
  delay(50);
  digitalWrite(sirenaPin,LOW);
  delay(50);
  digitalWrite(redLedPin,HIGH);
  delay(50);
  digitalWrite(redLedPin,LOW);
  delay(100);
  digitalWrite(blueLedPin,HIGH);
  delay(50);
  digitalWrite(blueLedPin,LOW);
  delay(100);
boolean senseAcceleration(int myPotVal){
  boolean myReturn=false;
  myPotVal=map(myPotVal,0,1023,0,10);
  if (analogRead(accXPin)>startAccX+myPotVal) myReturn=true;
  if (analogRead(accYPin)>startAccY+myPotVal) myReturn=true;
  if (analogRead(accZPin)>startAccZ+myPotVal) myReturn=true;
  return myReturn;
void loop(){
  //alertBlinking();
  switch (myState){
  case 0: //idle
    if (senseAcceleration(analogRead(potPin))==true) {
      digitalWrite(greenLedPin,LOW);
      myState=1;
      digitalWrite(greenLedPin,HIGH);
  case 1: // alert
    alertBlinking();
    if (digitalRead(buttonPin)==HIGH){
      myState=0;
  delay(10);
No entiendo mucho de esto, pero creo que cambiando la sirena por un chisme de esos de salida 5v a 12v y enchufando un claxon estaria listo. no?
 smiley-wink
Gracias...
Logged
Spain
Offline Offline
God Member
Arduino rocks
View Profile
Angael
Una pregunta sin animo de ofender ¿me da la sensacion que no controlas mucho de electronica verdad?
Es que si es asi yo te aconsejaria fueras mas despacio o con proyecto mas pequeño, empezando por cosas basicas.
Logged
CUIDADO !! MIS POST NO SON APTOS PARA MENORES. SI ERES MENOR DE 14 AÑOS DEBES DE LEERLOS ACOMPAÑADO DE UN ADULTO
En diseño te tienen que gustar más las preguntas que las respuestas [.Jray.]
Si estas empezando:
1- Comienza a usar Arduino
2- Guías de iniciación a Arduino
3- Ejemplos
4- Referencia del Lenguaje
5- Conceptos básicos
6- Guia de usuario de arduino
Offline Offline
Newbie
View Profile
Tranki. No ofendes. Pero es algo que me ha gustado de siempre y claro, hay que aprender. Esto no es poner piezas y ya esta. Pero pense que una alarma estaria bien para empezar. Ademas me interesaria montarla...
Si no es mucha molestia. Donde me estoy equivocando?
Logged
Spain
Offline Offline
God Member
Arduino rocks
View Profile
Te comento:
Un claxon es de los cacharros que mas bateria consume, muchos amperios... tendrias que conectarlo directo a bateria, una bateria de moto, con suerte es de 9A/h imagina lo cortito que vas de potencia electrica.
Un arduino conectado sin modo sleep, cosa que tendras que hacer para poder ir leyendo el acelerometro y el receptor de radiofrecuencia te va a consumir unos cuantos miliamperios, un par de dias conectado y si tu moto es de las que tiene la luz fija al arranque probablemente no puedas.
Calcula por ejemplo a grosso modo  300mA /h  x 24 horas = 7.2A.     si son dos dias   0.3 x 48 = 14.4A.
Aparte deberias añadirle un modulo de alimentacion con filtro y proteccion para alimentar el arduino, que ni te imaginas la porqueria de interferencias que lleva la tension de un vehiculo (moto o coche) aparte del margen en que se mueve.
Por otro lado, emplearias varias disciplinas, lectura de acelerometro y comprobacion, lectura de receptor de radio y transmision, lectura y manejo de gps... control de salidas o entradas... son varias cosas que juntas suponen mucho codigo e hilar muy fino.
No esta mal como proyecto pero tendrias que empezar paso a paso y poco a poco modulo por modulo.
Eso incluye toda la programacion...
¿Tienes pensado luego como meterias todos los modulos en una caja y en la moto? recuerda que no tenemos espacio (salvo los propietarios de Goldwin o Bmw)
¿una placa encima de otra o vas a diseñar una global?
Y todo sellado y sujeto...
Intento plantear el escenario, no desanimarte, al contrario, espero que pelees mucho con el arduino y todo lo que lleva alrededor...
« Last Edit: February 04, 2013, 04:07:52 pm by Heke » Logged
Si estas empezando:
3- Ejemplos
Offline Offline
Newbie
View Profile
Pues no queria meterle tantas cosas.
Habia pensado en un segundo claxon, conectarlo a la bateria. Pero que se activara despues de que el acelerometro registrara variacion de posicion.
Seria, solo el arduino, con el voltaje reducido.
Enganchado a los pines el acelerometro.
Y a otro pin la salida de 5v a 12v para activar el claxon de alarma.
Gracias!
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
