Topic: HC-SR04-LCD (Read 997 times) previous topic - next topic
cekstuffertz
Heey,
Is it possible to with the HC-SR04 to develop a system that allows you as the distance e.g.. lower than 40 cm you can control a lcd screen for a certain time?
Cekstuffertz
Less is more!
PaulS
It is possible to use a HC-SR04 to measure distances. It is possible to display that distance on an LCD screen. It would be helpful if you explained the "control a lcd screen" part. Usually, LCD screens are not unruly devices that need controlling. But, when they are, controlling them only for a certain time is not a good idea.
cekstuffertz
When the distance is lower then e.g.. 40 the lcd screen have to show a text for 30 seconds like:"Good job!"
Less is more!
UKHeliBob
Yes, perfectly possible.
Have you tried it ?
cekstuffertz
No because i don't control the c++ language yet. Can you help my with the code?
Cekstuffertz
Less is more!
UKHeliBob
You are going to have to put some effort in.
Do you have the hardware ?
HC-SR04 ?
LCD ?
Arduino ?
Power supply ?
cekstuffertz
Less is more!
UKHeliBob
Good news !
What example sketches have to tried ?
I assume that you have at least mad an LED blink
cekstuffertz
Less is more!
AWOL
And using the range finder and displaying the range on the serial monitor?
UKHeliBob
And displaying fixed text on the LCD
You can see which way this is going, can't you.
Baby steps maybe but remember "A journey of a thousand miles begins with a single step"
UKHeliBob
Things for you to do.
1. Get the Sensors/Ping example program working if you have not done so already.  Output goes to the serial monitor
2. Get the Liquid Crystal/Hello World program working if you have not already done so
3. Combine the 2 so that the Ping output goes to the LCD
Ask questions if you get stuck nut please post your code to help get answers
4. Change the program to put a different message on the screen when the ping distance is less than 40cm
