Topic: Help controlling a DC motor with pot pls (Read 562 times) previous topic - next topic
maxcamac11
Alright, simply put I have an arduino mega, an L298n H-Bridge motor driver, a DC motor, and a Pot.  I have everything hooked up.  I've looked everywhere on the internet and I know it may be simple as all heck but I cannot for the life of me find the right code to run this thing!  All I want it to do is to stop when the pot is in the middle, turn right and speed up when the pot is going further to the right, and visa versa for the left.  the H-Bridge has four inputs for two motors: 2 are PWM (for speed i'm guessing) and 2 for the polarity of each motor.  Someone please point me in the right direction, I will be forever great-full.
Grumpy_Mike
Quote
All I want it to do is to stop .................
So why are you looking for code why not write it? I would say the lines top.
If the answer is that you can't then how about learning. It opens up all sorts of possibilities and you might actually enjoy it more than trailing through the internet looking to see if some one has done it for you.
nickgammon
Quote
Tell you what I do, I write the minimal amount of code to make "something happen", then expand on it.
Your first attempt might be to read the pot, and display the values you get on the serial port. That gives you a feel for the numbers you are working with.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
zoomkat
Some search results.
http://www.google.com/search?num=100&hl=en&lr=&tbo=d&as_qdr=all&q=pot+pwm+motor+h-bridge+site%3Ahttp%3A%2F%2Farduino.cc%2Fforum&oq=pot+pwm+motor+h-bridge+site%3Ahttp%3A%2F%2Farduino.cc%2Fforum&gs_l=serp.3...14542.19148.0.20016.8.8.0.0.0.0.54.361.8.8.0.les%3B..0.0...1c.1.Ymgm5AOrluM
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
nickgammon
The AnalogInOutSerial sketch that comes with the IDE would assist you in that.
Grumpy_Mike
Quote
IPad auto corrector I typed in "ten lines top"
nickgammon
