i have have been building a robotic arm with a 1:1 mirroring controller. i need help with how to get my button hooked up so that with one press the servo goes one way (makeing the claw open) then releace the button and make the servo turn the other way. i have tryed many different setups but i cant get this working.
// Remote Sketch
// by david21n
// Simple sketch for one to one robot arm project
#include <Servo.h>
Servo servo1; // create servo object to control a servo
Servo servo2; // a maximum of eight servo objects can be created
Servo servo3;
Servo servo4;
Servo servo5;
Servo servo6;
Servo servo7;
// States of the claw
const int OPEN = 0;
const int CLOSED = 1;
const int OPENING = 2;
const int CLOSING = 3;
// claw close and open positions
const int closeClaw1 = 160;
const int openClaw1 = 105;
const int closeClaw2 = 15;
const int openClaw2 = 70;
// intial values of servos
int val1 = 90; // Joint 1 (Base)
int val2 = 90; // Joint 2 (Close to base)
int val3 = 90; // Joint 3 (Middle)
int val4 = 90; // Joint 4 (End)
int val5 = 90; // Joint 5 (Rotate the claw)
int valClaw1 = 160; // claw 1
int valClaw2 = 15; // claw 2
// Movement of the Servos
// - each servo moves depending how it is mounted
// Joint 1 (Base) --- right = 0, left = 180
// Joint 2 (Close to base) --- back or up = 0, forward or down = 180
// Joint 3 (Middle) --- back or up = 0, forward or down = 180
// Joint 3 (End) --- back or up = 180, forward or down = 0
// analog pins
const int input1 = 3; // Base
const int input2 = 2; // Joint 1 (Close to base)
const int input3 = 1; // Joint 2 (Middle)
const int input4 = 0; // Joint 3 (End)
// The potentiometers would be read and adjusted to
// a value between 0 and 180 that the servo function
// can use. But, the potentiometers goes father than
// 180 degrees, so the program need parameters.
// To get these parameters run the "Sense" sketch
// and write down the values of the joint when the
// potentiometer is at 0 and 180 degrees.
// IMPORTANT: make sure the 0 degree position of the
// potentiometer is the same as the 0 degree position
// of the servo. If the 0 degree positon of potentiometer
// is the 180 degree position of the servo, the servo
// would go the reverse direction of the potentiomter
// Joint read values at 0 and 180 degrees
const int deg1[] = {205,935};
const int deg2[] = {95,830};
const int deg3[] = {210,915};
const int deg4[] = {130,830};
// scales used to scale input value to 0 to 180
// scale = (deg180 - deg0) / 180;
const float scale1 = 3.91;
const float scale2 = 3.91;
const float scale3 = 4.08;
const float scale4 = 3.89;
// Joint offset
// The offset is when the servo is not mounted
// correctly by a few degrees, so an offset is applied
// to correct it.
const int offset1 = 0;
const int offset2 = 5;
const int offset3 = -5;
const int offset4 = 5;
// Claw increment
const int incClaw1 = -5;
const int incClaw2 = 5;
// Led pin to show arduino is on
int ledPin = 13;
// Claw variables
int buttonPin = 12;
int buttonState = 0;
int clawState = CLOSED;
// attach servos
servo1.attach(0); // BASE
servo2.attach(1); // Joint 1
servo3.attach(2); // Joint 2
servo4.attach(3); // Joint 3
servo5.attach(5); // Joint 4 rotate
servo6.attach(6); // claw 1
servo7.attach(7); // claw 2
// led pin
pinMode(ledPin, OUTPUT);
// Turn on led
digitalWrite(ledPin, HIGH);
// Read the potentiometers
val1 = analogRead(input1);
val2 = analogRead(input2);
val3 = analogRead(input3);
val4 = analogRead(input4);
// Adjust the read values
val1 = adj(val1, deg1, scale1, offset1);
val2 = adj(val2, deg2, scale2, offset2);
val3 = adj(val3, deg3, scale3, offset3);
val4 = adj(val4, deg4, scale4, offset4);
// Send out signal to servos
servo1.write(val1);
servo2.write(val2);
servo3.write(val3);
servo4.write(val4);
servo5.write(val5);
servo6.write(valClaw1);
servo7.write(valClaw2);
// read the state of the pushbutton value:
// Check if the pushbutton is pressed.
// if it is, the buttonState is LOW,
// changes the claw state
if ((buttonState == LOW))
if (clawState == CLOSED)
clawState = OPENING;
else if (clawState == OPEN)
clawState = CLOSING;
// if claw is opening or closing, increases
// or decreases the servo value
if (clawState == OPENING)
if(valClaw1 > openClaw1 && clawState == OPENING)
valClaw1 += incClaw1;
valClaw2 += incClaw2;
clawState = OPEN; // claw is open
else if (clawState == CLOSING)
if(valClaw1 < closeClaw1 && clawState == CLOSING)
valClaw1 -= incClaw1;
valClaw2 -= incClaw2;
clawState = CLOSED; // claw is closed
// delay for the servo to
// move to the new position
delay(15);
// The function adjusts the analog read value to degrees
int adj(int input, const int deg[], const float scale, const int offset)
float val = 0;
// scales the value to 0 to 180
if ( input < deg[0])
val = 0;
else if ( (input >= deg[0]) && (input <= deg[1]) )
val = (input - deg[0])/scale;
else if (input > deg[1])
val = 180;
// add offset
val = val + offset;
// fix max and min
if (val > 180)
val = 180;
else if (val < 0)
val = 0;
return val;
maybe if someone could help me figure this out. or mabey change the code so that one button opens the claw and the other would close it. that would be extremely help full. i am new to writing code and need all the help i can get. please get back to me. if you need you you could email me at (
erik102696@gmail.com). also this is the website that i got the idea from and the code
http://letsmakerobots.com/node/22346
