Loading...
Pages: [1]   Go Down
Author Topic: Remote vehicle ignition  (Read 304 times)
Seaford, Victoria, Australia
Offline Offline
Jr. Member
View Profile
Hi there!
Some might remember me from around 7 months ago, i had an idea to make a remote vehicle ignition that could start a car via txt message.
Well, some months on i've pretty much finished the project, and all runs well in my EFI car and has done for months without a hitch.
I've got a friend who has an old toyota hilux and wants me to install one, the problem being this:
The way my prototype works is, it receives the ignition code/pin via text message through the GSM board, then checks to see whether the car is already running; if not it will then put the car onto the reds (ON), then after a few seconds it will proceed to fire the starter motor.
It will do this until either until a 10 second timer is up or it senses 12v from a random wire i found behind the dash that is only powered when the car is running, therefor it assumes the car is running and shuts off the starter motor.
The problem is this, my friends old non EFI hilux doesn't have a computer nor any other 12 source that i can find that is live only when the car's engine is running.
What possible ways would there be for my arduino to detect that the vehicle is running after cranking and thus turn off the starter motor?
Would an option be to make a revolution sensor?
Regards!
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
Try reading a spark plug wire with a Hall sensor.
Or maybe engine vibration with a piezo disk.
Logged
Examples can be found at Learning in the Main Site and at the Playground
Offline Offline
Jr. Member
View Profile
I'll look into it!
Hopefully i can find a solution that works within 1000ms or less, as starter motors arn't cheap smiley-wink
Thanks!
Logged
N. Illinois
Offline Offline
Newbie
View Profile
Try the Tachometer, you know its running if the tach is at a certain rpm.  That's what most off the shelf remote starters use.
Logged
UK
Offline Offline
Tesla Member
View Profile
Running during cranking is what you really need. The only reliable way I can see is to monitor engine RPM. If it's below about 300 rpm, the engine is cranking. Over 300 rpm (for longer than say a second) implies that it is running.
Logged
Dee Why NSW
Offline Offline
God Member
View Profile
You could take a signal off the alternator. I think they get it off the exciter winding. This is, or was, standard practice for dual fuel vehicles and is used to change over to gas immediately after starting.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Spark timing is good and not all cars I've seen have a tach, but IMO tach data is best.
Logged
New Jersey
Offline Offline
Edison Member
View Profile
Did you ever publish a writeup on the mark one version?
Logged
Offline Offline
Jr. Member
View Profile
Thanks guys for all the inputs! i guess the logical way to go would be to read the tach and make a decision based off of that.
Wildbil, no i havn't as of yet.
The code for the project was mostly written by another member on this forum, as i'm quite new to the world of arduino i'm not that fluent with the language yet and had no idea how to create a state machine, but i will try and implement the tach sense completely myself..
Will update and do a project write up once it is completely finished smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
