Topic: 11.1V 1300mAh LiPo Battery and Arduino (Read 6705 times) previous topic - next topic
xFinaLx
Jan 30, 2013, 12:26 am Last Edit: Jan 30, 2013, 12:36 am by xFinaLx Reason: 1
Is it safe to use a 11.1V 1300mAh LiPo Battery designed for RC cars/planes with my new Arduino Nano? I read that the Nano can operate on 6-20V with 7-12V being recommended, so it sounds to me like it would be fine?
Also, I know I plug the positive lead into VIN (pin 30) so do I plug the negative lead into GND?
It's been a while since I've done any electronics tinkering, please excuse my noobiness.
Thanks!
MarkT
Yes that should be fine.  If you are using the Nano to supply lots of current its regulator might get quite hot though -
the higher the Vin the more heat.  In fact current x (Vin - 5) = heat power to the regulator.
Given its a high current battery it would be wise precaution to add say a 1A or 500mA fuse on the wire to Vin if possible.
You must be very careful never to short out a LiPo pack, they can source huge currents.
xFinaLx
Sweet, some great tips! Question - if I short out digital outputs (by accident, of course) would that be equivalent to shorting out the LiPo itself?
retrolefty
No the output pin has more resistance then the battery pack so it would blow something open well before the battery felt the full effects of the short circuit. Fusing your main battery pack is still a good idea, especially for Li-Po cells as they can source a lot of current and overheat and do bad things like catch on fire.
Lefty
nickgammon
If you use the barrel jack (rather than Vin) you get the benefit of the reverse-polarity protection, plus that diode drops 0.7V which takes some of the load off the voltage regulator.
xFinaLx
I'm using the Nano though, no barrel jack.
nickgammon
teckel
Thanks!
It would be more ideal to use a 2 cell battery (7.4 volts).  But, your 3 cell battery would also work.  For almost all of my battery-powered projects I use a 2 cell LiPo battery.  However, if you plan on running something for a long time that could result in total drainage you should consider monitoring the battery voltage and when tripped it goes into low power mode (watchdog timer) and triggers an alarm. You'll kill your LiPo battery if you drain it to 0 volts, or even 9 volts in your case.  Use a resistor-based voltage divider and the internal 1.1 volt reference of the Arduino to measure your battery voltage.
Tim
My platforms Arduino, Teensy 3.2, Arduino Pro Mini, ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
Ironman1100
If I am using a 11.1V 2200mAh LiPo battery to do the same thing what would be the fuse that I use?
