Loading...
Pages: 1 ... 3 4 [5]   Go Down
Author Topic: Can't find old topic on clock compensation  (Read 1252 times)
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Just to prove it to myself, I made this amended sketch:
Code:
#include <avr/sleep.h>
#include <avr/power.h>
const byte tick = 3;
// interrupt on Timer 2 compare "A" completion - does nothing
EMPTY_INTERRUPT (TIMER2_COMPA_vect);
  pinMode (tick, OUTPUT);
  // clock input to timer 2 from XTAL1/XTAL2
  ASSR = _BV (AS2);
  // set up timer 2 to count up to 32 * 1024  (32768)
  TCCR2A = _BV (WGM21);                             // CTC
  TCCR2B = _BV (CS20) | _BV (CS21) | _BV (CS22);    // Prescaler of 1024
  OCR2A =  31;              // count to 32 (zero-relative)
  // enable timer interrupts
  TIMSK2 |= _BV (OCIE2A);
  // disable ADC
  ADCSRA = 0;
  // turn off everything we can
  power_adc_disable ();
  power_spi_disable();
  power_twi_disable();
  power_timer0_disable();
  power_timer1_disable();
  power_usart0_disable();
  // full power-down doesn't respond to Timer 2
  set_sleep_mode (SLEEP_MODE_PWR_SAVE);
  // get ready ...
  sleep_enable();
  }  // end of setup
  // turn off brown-out enable in software
  MCUCR = _BV (BODS) | _BV (BODSE);
  MCUCR = _BV (BODS);
  // sleep, finally!
  sleep_cpu ();
  // we awoke! pulse the clock hand
  digitalWrite (tick, ! digitalRead (tick));
  }  // end of loop
With the 32.768 KHz crystal the LED (on pin 3 toggles every second). Now as this is under software control, you could do anything you want in the main loop, instead of the digitalWrite (eg. update a display).
The current consumption, when the LED is not lit, was 1.46 uA, which is pretty low.
(edit) And 1.1 uA at 3.3V power supply.
« Last Edit: February 01, 2013, 12:25:56 am by Nick Gammon » Logged
Offline Offline
Newbie
View Profile
Okay, I am seriously upset/confused right now.
When I use your code (with the EMPTY_INTERRUPT), changing the value of OCR2A changes the frequency of the blinking. As expected.
If I change EMPTY_INTERRUPT to an ISR, move the digitalWrite up into the ISR, and comment out all the sleepy-stuff, changing OCR2A has no effect at all. Zip. Nada. Using the exact same TCCR2A/B values. The frequency is always the base frequency of the prescaler, as if OCR2A is 0.
What am I not seeing here?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Post the amended sketch, don't just describe it.
Logged
Offline Offline
Newbie
View Profile
Code:
const byte tick = 11;
ISR(TIMER2_COMPA_vect) {
  ASSR = _BV (AS2);
  OCR2A =  15;              // count to 32 (zero-relative)
  // disable ADC
  ADCSRA = 0;
  // get ready ...
  sleep_enable();
  }  // end of setup
  MCUCR = _BV (BODS);
  // sleep, finally!
  sleep_cpu ();
  }  // end of loop
Always blinks at 15.99 Hz, regardless of ACR2A.
Thanks!
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
To save fetching out the board with the extra crystal, I tried on my Uno this slight variation:
Code:
  ASSR = _BV (AS2);
  OCR2A =  63;              // count to 64 (zero-relative)
  }  // end of setup
void loop() { }
This gave a frequency of 122 Hz as predicted by the theory:
Code:
1 / (1/16e6 * 1024 * 64) / 2 = 122.0703125
You divide by 2 because it takes two pulses to complete one cycle. Changing OCR2A changed the frequency.
Logged
Offline Offline
Newbie
View Profile
I've still got the problem. Changing the prescaler changes the frequency; changing OCR2A changes absolutely nothing. I guess there's something screwy inside the chip, and I'll just work around that in my code.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Are you measuring the right pin?
Sometimes I found that where the OCR2A line was affected thing. Try moving that line earlier up.
Logged
Offline Offline
Newbie
View Profile
Well! I tried moving the OCR2A line up; nothing changed. I added the TCCR2A = 0 and TCCR2B = 0 lines at the top and it works! Which is strange, because in other non-working sketches I've tried it hasn't worked. Must've been a combination of that and moving the OCR2A line.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Adding those lines stops the timer. I think in some modes the OCR2A changes are buffered, so it makes some sense to stop it first.
Logged
Pages: 1 ... 3 4 [5]   Go Up
Print
Jump to:
