Pages: 1 2 [3] 4 5   Go Down
Author Topic: Can't find old topic on clock compensation  (Read 1208 times)
Did you mean to attach something?
Funny, I thought I did! Here's the download right from Atmel: http://www.atmel.com/Images/AVR4100.zip
EDIT: Whoa. I just now noticed that it's 4100, not 4001. I've been looking at that doc for a couple weeks now, and always thought it was 4001. Sorry for any unnecessary hassle!
« Last Edit: January 30, 2013, 03:24:50 pm by randomizer » Logged
Grand Blanc, MI, USA
"We're a proud service of the Lost Electricity Reclamation Agency"
Ha! No worries, I didn't quite make a career out of searching for it!
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Got it! I realized I was being too lame—expecting the Atmel code to work perfectly. This is how I set it up (with an interrupt cobbled from various people online):
delay(1000); //give watch crystal time to stabilize
// initialize Timer2
    cli();          // disable global interrupts
    ASSR = (1<<AS2);
    TCCR2A = 0;     // set entire TCCR2A register to 0
    TCCR2B = 0;     // same for TCCR2B
    TCCR2A |= (1 << WGM21); // Configure timer 2 for CTC mode
    TIMSK2 |= (1 << OCIE2A); // Enable CTC interrupt
    TCCR2B = (0<<WGM22)|(0<<CS22)|(0<<CS21)|(1<<CS20); //no prescaler
    OCR2A = 0;           //trigger interrupt every clock cycle
    // enable global interrupts:
    sei();
pinMode(9, OUTPUT);
ISR(TIMER2_COMPA_vect){
    digitalWrite(9,HIGH);
    digitalWrite(9,LOW);
void loop() {}
I get 16.38 kHz on my DMM. Assuming that it's not trying to say 16.384, that's ~120ppm (thanks Wolfram|Alpha!). So I don't see why my clock should have been so far off. Perhaps any inaccuracies in the chip get amplified with the prescaler? For the clock, I was prescaling by 1024 to get a 1Hz interrupt...
EDIT: Hmmmmmm. Setting OCR2A to 33 instead of 0 (this is really useful), I get 952.5 Hz instead of 1000 Hz. Or I was, until the DMM decided to quit on me. Aaaaaarg.
« Last Edit: January 30, 2013, 04:19:20 pm by randomizer » Logged
Melbourne, Australia
Shannon Member
Lua rocks!
You can't usefully do that with no prescaler. Servicing an interrupt takes at least 19 clock cycles (see: http://www.gammon.com.au/interrupts), then your digital writes will take time, plus the time to leave the ISR.
It will work perfectly, on its intended target.
All you need to do is to understand what the code is doing, read the datasheet of your own target and replicate the same on your target: aka what an application note is designed to do.
You can't usefully do that with no prescaler. Servicing an interrupt takes at least 19 clock cycles.
19 system clock cycles, yes? I'm clocking TIMER2 asynchronously. That's how the Atmel code did it:
#ifdef ATMEGA48_88_168
int main( void )
// Crystal clock will be output on PORTB3 (divided by 2)
DDRB |= (1<<PORTB3);
// Enable CTC mode with toggle on compare match. Precale 1 and top at 0
OCR2A  =  0;
TCCR2A = (0<<COM2A1)|(1<<COM2A0)|(1<<WGM21)|(0<<WGM20);
ASSR   = (1<<AS2);
while(1){}
#endif
Not using timer interrupts, just using output compare to make its frequency measurable on a pin. Well, half it's frequency is the best that can be done.
Shannon Member
Lua rocks!
Oh, OK. Sure.
No. The latency varies, depending on many factors, starting from as low as 2.
Shannon Member
Lua rocks!
OK, I'm calling you on this one, dhenry. From the datasheet, which you keep recommending people read:
Since we do indeed use an interrupt vector, that is 7 cycles minimum. Add onto that the code in the ISR to, at the very least, save the status register (SREG) and that is another 3 cycles. On top of that you have to push any registers you are planning to use, unless your ISR doesn't do anything.
So, no, it is not "as low as 2".
I was wrong about the 19 cycles. That is the time take, from looking at actual code generated, to leave the ISR. It is 23 cycles to enter it. That would probably vary depending on what the ISR does. The more things it does, the more registers the compiler has to save (and restore later).
Figures, disassembly, etc. on this page:
It's interesting—with OCR2A set to 0 or 1, I get, as expected, half of 32768—1638(4). But when I up OCR2A to ~31,32,33 to get a 1kHz frequency, I get a 1kHz frequency (or close to it)—not 500Hz. I think that's because in the interrupt, I have
instead of
if (toggle2){
    toggle2 = 0;
  else{
    toggle2 = 1;
which is what it was originally. At the relatively high frequencies, the minuscule gap between HIGH and LOW is... something, and at lower frequencies it... isn't. Not really sure what I'm saying exactly, but I know what I mean. smiley
At OCR = 0, you get 16khz;
OCR = 1, you get 8khz;
OCR = 31, you get 0.5khz.
Well, with the original code (using the toggle) I find that OCR=1 generates 1/2 of 16384Hz (interestingly, so does OCR=0). At least, it should. I'm reading 8190, which is ~250ppm off—way more than the ~40 expected from the temperature. That could well be errors in the DMM—I don't really see what else, unless the crystal is picking up parasitic capacitance through the air from the breadboard rails underneath it.
That translates to 21 seconds per day slow, if I define a second as 8292 interrupts. (Or I could just code it as 8190, and assume that my meter isn't off.) That's not ideal, but it's not the second-every-five-minutes loss I was having before.
One thing I've determined: The calculator I linked to earlier rounds the answer it spits out—when I say I want 4 kHz, for example, it tells me I can use no prescaler and OCR=8 and have 0% error, but the fact is I will have error because everything's in factors of two. Nominal 8 kHz is actually 8192 Hz. This is possibly why the clock was so slow earlier.
Shannon Member
Lua rocks!
Get the timer to toggle a pin, don't rely on an ISR to do it.
What? I thought the ISR was the manifestation of the timer. Are you saying something like this?
if (TCNT2 = 3){
//toggle pin
Because the reason I wanted an interrupt in the first place is so I can sleep the chip in the meantime. I don't know if it's really worth the 17 mA, especially when there'll be lots of LEDs on anyway. But that was my idea.
« Last Edit: January 30, 2013, 09:17:55 pm by randomizer » Logged
Pages: 1 2 [3] 4 5   Go Up
