Topic: Getting a 1us delay (Read 4018 times) previous topic - next topic
jean507
I am trying to measure a time of 1us. I realized the micros() function is only accurate to 4us. I was trying to use the following code to increment a variable every 1us. So far "MicroSecClock is always equal to 0. Is that the right strategy to capture 1us resolution? Thank you
uint32_t MicroSecClock = 0;
ISR(TIMER2_OVF_vect) {
  static uint8_t count;            // interrupt counter
  if( (++count & 0x01) == 0 )     // bump the interrupt counter
    MicroSecClock++;              // & count uSec every other time.
  TCNT2 = 253;                    // reset counter 2MHz interrupt rate
  TIFR2 = 0x00;                   // clear timer overflow flag
jean507
Perhaps, I may add that my goal is to make my own "micros()" function that is precise up to 1us rather than 4 us. Since I read that the micros() function is based upon the timers, I figured I had to come up with my own manipulation of the timers to achieve a 1us granularity. I'm just looking for pointers on the best way to accomplish this.
Thank you
dhenry
At 16Mhz, it takes 1us to execute 16 nop instructions.
retrolefty
Thank you
Probably harder then it might first appear depending on if you make it a blocking function or have to have it co-exist in an interruptible environment?
Lefty
Coding Badly
Which?  Measure an elapsed time of 1 us or measure something with a resolution of 1 us?
jean507
I am trying to measure something with a resolution of 1us. I was thinking that measuring and elapse time of 1us would allow me to do just that.
Jean
holmes4
I think that you will find that the Arduinos are just to slow to do this.
Mark
dc42
I would set up timer 1 to run direct from the system clock, no prescaler. Wait in a tight loop for the input pin to change, using direct port i/o, then read the timer. Wait in another tight loop for the pin to change again, then read the timer again. You should be able to code the loops to run in less than 0.5us (i.e. less than 8 clock cycles), so 1us resolution should be just about achievable.
Alternatively, feed the signal to the input capture pin (or to the analog comparator), and use the input capture facility of timer 1 to record the times of the input transitions. That will give you a resolution of about 0.125us, however the shortest time you can record will be a few us.
michinyon
If you are trying to measure some small interval,  devise a circuit which starts a pulse when
the first event occurs and ends the pulse when the second event occurs.
Then use the pulse you created to charge up a capacitor.
And then measure the voltage achieved in the capacitor while it was accumulating current
during the pulse.
It is not that easy to measure 1 us,  the Arduino is not fast enough to do it using software.
Coding Badly
That is not correct.
Coding Badly
That's what I would do.  It works very well.  There are examples available on the internet and probably on this forum.
0.0625us.  No prescaler means the clock ticks with the processor.
If I remember correctly, the shortest elapsed time I was able to "input capture" was 3 us.
The drawback is that you have to use a 16 bit timer (timer 1 on the Uno).
Coding Badly
dhenry
Use the capture function.
GoForSmoke
during the pulse.
I have charged a cap (I forget the circuit but it included changing a pin from OUTPUT to INPUT to take advantage of the high INPUT impedance -- to me that is like <usec circuit rewiring) and counted loops till it bled out to ground through a resistor. That let me -stretch out- the measure. IIRC I was playing around with capsense at the time.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
jean507
Does anybody have a working code snippet I could use to achieve that?
