Loading...
Pages: [1]   Go Down
Author Topic: ARDUINO MICRO question  (Read 252 times)
Offline Offline
Newbie
View Profile
Wassup forum!
I am trying to power a microcontroller and LED strip off of ONE BATTERY. The LED strip needs a clean 5 V and may use close to an amp, but never actually 1 Amp.  I have found some batteries for RC purposes that are 4.8 volts and I think would work for the strip, but the Micro needs more than that to run clean.
I would ideally like to replace the battery as needed, a connector on the micro could make for quick battery replacement.
If I put 4.8 to the Micro will it run correctly?
If I put 6 V or higher to the Micro, are there pins on the Micro that will deliver a clean 5 volts out, able to handle close to 1 amp?
It seems the Teensy is another option, but Im just more familiar with the Arduino environment.
Thanks for any insight.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
You can put 5V or under to the 5V pin (not going through the voltage regulator). You should be able to run down to 3.3V without too many problems.
I hope, if you are planning to put out around an amp to run the LEDs that MOSFETs or similar are in your design.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
AVR chips will run down to 1.8V so 4.8V is plenty. Just make sure you connect it to the right input.
Then you'd better connect it through the power plug which has a voltage regulator to drop it down to 5V.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
You can put the 4.8V into the 5V pin on the power header. Use a 1N4001 diode from 5V (anode) to Vin (cathode) to prevent any regulator damage.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Pages: [1]   Go Up
Print
Jump to:
