Topic: Is there a good Basic interpreter? (Read 24960 times) previous topic - next topic
DevilsChild
Okay... But how can I execute a set of instructions, and how can I compile assembly code into binary code?
AWOL
Quote
The gcc compiler is really good at that.
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
DevilsChild
That still leaves the question on how to execute a set of binary code on the Arduino. I think you need to add the instruction pointer on the stack, then excecute the binary code and at the end of that code pop esi and jump to it, right? Though I haven't found any examples yet...
Also, is it possible to compile asm on the Arduino?
johncc
Hmmm
"...lightweight interpreter..." , "... sources evolving...", "... life perfecting ..."
Of course!
....+++--->  brainf*ck
http://hackaday.com/2013/01/29/genetic-algorithms-become-programmers-themselves/
Oh.  And this guy has already written the interpreter for atmega:
http://www.omnimaga.org/index.php?topic=15152.0
Cheers,
John
AWOL
Quote
The bootloader allows you to do that.
DevilsChild
I know, but I meant from within running code, like this:
Code: [Select]
   char *binary = .....
   push esi
   execute(binary);
   pop esi
KeithRB
Forth might be a good option:
http://arduino.cc/forum/index.php/topic,8838.0.html
nickgammon
Got another idea: What about an assembly compiler on the Arduino? Pass ASM code as string and get binary code as return and then execute it by setting the instruction pointer? Is that somehow possible or does it sound ridiculous?
Not possible. On these processors (Harvard architecture) you can't execute code from RAM.
http://en.wikipedia.org/wiki/Harvard_architecture
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
0AlphaOmega
Got another idea: What about an assembly compiler on the Arduino? ....
Do you mean ON the Arduino or FOR the Arduino?
For whom does the clock pulse? It pulses for you!
DevilsChild
I meant on the Arduino from memory. Well, as Nick stated, it is not possible. I think I'm best off by writing my own Basic interpreter. It shouldn't be so hard, I've written one a couple of years ago. When something useful comes around, I'll share it :)
Again, thank you all for help. I will also take a closer look at bitlash and some of the posted links.
KeithRB
Here is one:
#include <stdio.h>
#define Q r=R[*p++-'0'];while(
#define B ;break;case
char*s="Qjou!s\\311^-g\\311^-n\\311^-c\\::^-q-ma%mO1JBHm%BQ-aP1J[O1HB%[Q<nbj\
o)*|gps)<<*txjudi)m*|aQdbtf!::::;sfuvso<aQefgbvmu;aQ<m,,a%CQ<csfbla%bQ<aN2!Q\
\ndbtf!aP2Q;m>aP2Q<a%!D12J!JGJHJOJQJFJSJJJMHS%HD12D12N3!N4\nJUJT%UQm>aP4HC%T\
Qs\\q,,^>m,2<m>aP4HC%SD12N1\nJNQm>s\\..q^aHC%NHb%GN1!D32P3%RN1UP1D12JPQUaP1H\
R%PN4\nQ<g\\(aP3Q(^>aP2Q,2<n\\(aP3Q(^>aP4Hb%OD12D12N2!N3\nJVP3Q,,<jg)aP3Q=>n\
\\(aP3Q(^*m>g\\(aP3Q(^<fmtf!m,,aHC%QN1!N1\nJ#Qqsjoug)#&e]o#-aP1Q*aHb%#Qqvut)\
aP1Q*aHb%FN1\nQm>::::aHC%VP3Q>bupj)hfut)c**aHb%JD12JON1!Qjg)a%LN1UP1D12JIQUa\
P1HL%IQ*m>aN2!N2\nP2Q<fmtf!m,,aHC%MN1!N2>P2Q>aN2\nP2Hbdd!b/d";k;char R[4][99]
;main(c,v)char**v;{char*p,*r,*q;for(q=s;*q;q++)*q>' '&&(*q)--;{FILE*i=fopen(v
[1],"r"),*o=fopen(q-3,"w");for(p=s;;p++)switch(*p++){B'M':Q(k=fgetc(i))!=EOF
&&k!=*p)*r++=k;if(k==EOF){fputs("}}\n",o);fclose(o);return system(q-6);}*r=0
B'P':while(*p!='`')fputc(*p++,o)B'O':Q*r)fputc(*r++,o);p--B'C':k=0;Q k<*p-'0'
)(*r++=fgetc(i),k++);*r=0 B'I':k= *p;if(**R==k)goto G B'G':k= *p;G:p=s;while(
*p!='$'||p[1]!= k)p++;p++B'N':R[*p-'0'][0]++;}}}
8^)
Chaul
I used to code in Visual Basic 6 for a living... hopefully never again. I've slowly evolved to languages that actually work and make sense.
dhenry
Quote
Nothing is difficult, until you start doing it.
johncc
Here is one:
#include <stdio.h>
8^)
CODE TAGS!!!!
nickgammon
The mind boggles. Truly.
