Author Topic: How to Read Data from BMA180, but always in the positive range?  (Read 425 times)
Hi, i try to read data from BMA180 accelerometer. So far, i did it using code from:  http://www.electrodragon.com/?p=3660
This is the complete code:
#include <Wire.h>
  Wire.begin();
  Serial.println("Demo started, initializing sensors");
  AccelerometerInit();
  Serial.println("Sensors have been initialized");
void AccelerometerInit()
  Wire.beginTransmission(0x40); // address of the accelerometer
  // reset the accelerometer
  Wire.write(0x10);
  Wire.write(0xB6);
  Wire.endTransmission();
  delay(10);
  // low pass filter, range settings
  Wire.write(0x0D);
  Wire.write(0x10);
  Wire.write(0x20); // read from here
  Wire.requestFrom(0x40, 1);
  byte data = Wire.read();
  Wire.write(0x20);
  Wire.write(data & 0x0F); // low pass filter to 10 Hz
  Wire.write(0x35); // read from here
  data = Wire.read();
  Wire.write(0x35);
  Wire.write((data & 0xF1) | 0x04); // range +/- 2g
void AccelerometerRead()
  Wire.beginTransmission(0x40); // start transmission to device, address of the accelerometer
  Wire.write(0x02); // send register address, set read pointer to data
  Wire.requestFrom(0x40, 6);
  // read in the 3 axis data, each one is 16 bits
  // print the data to terminal
  Serial.print("Accelerometer: X = ");
  short data = Wire.read();
  data += Wire.read() << 8;
  Serial.print(data);
  Serial.print(" , Y = ");
  data = Wire.read();
  Serial.print(data);
  Serial.print(" , Z = ");
  data = Wire.read();
  Serial.print(data);
  Serial.println();
  AccelerometerRead();
  delay(500); // slow down output
The problem is, the data range for X, Y and Z axis from the sensor is always in the range -17000 to 17000. I want to get data only in positive range, how i can do that?
Thank You..
Switzerland
Change the type of the variable:
  uint16_t data = Wire.read();
  Serial.print(data);
Although the correct value is:
  data >>= 2;
  Serial.print(data);
because bit 0 and 1 of the LSB are "new_data" flag and 0.
The acceleration value is inherently negative and positive.
You need to be clear,  why you think you want only positive values.  What are you
trying to achieve ?
If you just want to know the magnitude,  take the absolute value.
@pylon:
Thanks, i will try it..
@michinyon:
i want to make 3 axis gimbal for my project. I use 3 servo motors and this Multiwii board:
https://www.hobbyking.com/hobbyking/store/__27033__MultiWii_328P_Flight_Controller_w_FTDI_DSM2_Port.html
Those board is Arduino based. There are 4 sensors, but i just use BMA180 accelerometer and ITG3205 Gyroscope for my 3 axis gimbal. The Multiwii board is coming with the program, but the gimbal program is only for 2 Axis. Besides that, I want to make a program by my self from the beginning.
So i learn all from beginning, including reading data from BMA180..
can you help me in making 3 axis gimbal? is there anything that can be a reference for me?
Thank You..
« Last Edit: January 30, 2013, 09:33:32 pm by mamette » Logged
acceleration can occur in two directions.    So for three axes,  there are six directions.
It can be accelerating forwards or backward,  up or down,  left or right.  Thats six.
Thats why you get three numbers which may be positive or negative.
It's unclear why you only want positive numbers.   If the sensor tells you -2000,  what do you want ?    0  or  +2000 ?
If you want the total magnitude of the acceleration,  you would calculate the length of the apparent acceleration vector,
which would be something like
a_magnitude =  sqrt (( a_x * a_x ) + ( a_y * a_y ) + ( a_z * a_z ))
which will always be a positive number.
So far, i found 3 different example to read data from BMA180. Each of them have different output value.
The First Code is in first Post on this thread..
And this is the Second Code:
 * BMA180_I2C_Example.pde ----- Sample sketch for BMA180 Accelerometer using I2C
 * A sample sketch that shows the basic functions of the BMA180 acclerometer.
 * 2011, DSS Circuits, Inc.  http://www.dsscircuits.com
#include <Wire.h>
#define BMA180              0x40
#define ee_w_MASK           0x10
#define mode_config_MASK    0x03
#define bw_MASK             0xF0
#define range_MASK          0x0E
#define lat_int_MASK        0x01
#define lat_int             0x01
int x,y,z,temp;
  Wire.begin();
  initializeBMA180();
  Serial.write(0x0D);
  readAccel();
  printAccel();
  Serial.write(0x20);
  delay(200);
byte readAccel()
  Wire.beginTransmission(BMA180);
  Wire.write(0x02);
  if(Wire.endTransmission()){return(1);}
  if(Wire.requestFrom(BMA180,7) != 7){return(2);}
  x = Wire.read();
  x |= Wire.read() << 8;
  x >>= 2;
  y = Wire.read();
  y |= Wire.read() << 8;
  y >>= 2;
  z = Wire.read();
  z |= Wire.read() << 8;
  z >>= 2;
  temp = Wire.read();
void printAccel()
  Serial.print("X = ");
  Serial.print(x);
  Serial.print("  ");
  Serial.print("Y = ");
  Serial.print(y);
  Serial.print("  ");
  Serial.print("Z = ");
  Serial.print(z);
  Serial.print("  Temperature(C) = ");
  Serial.println(map((int8_t)temp,-128,127,-400,875)/10.0,1);
byte initializeBMA180()
  /*Set EEPROM image to write mode so we can change configuration*/
  delay(20);
  Wire.write(0x0D);
  if(Wire.requestFrom(BMA180,1) != 1){return(2);}
  byte ee_w = Wire.read();
  ee_w |= ee_w_MASK;
  Wire.write(0x0D);
  Wire.write(ee_w);
  delay(20);
  /*Set mode configuration register to Mode 00*/
  Wire.write(0x30);
  byte mode_config = Wire.read();
  mode_config &= ~(mode_config_MASK);
  Wire.write(0x30);
  Wire.write(mode_config);
  delay(20);
  /*Set bandwidth to 10Hz*/
  Wire.write(0x20);
  byte bw = Wire.read();
  bw &= ~(bw_MASK);
  bw |= 0x00 << 4;
  Wire.write(0x20);
  Wire.write(bw);
  delay(20);
  /*Set acceleration range to 2g*/
  Wire.write(0x35);
  byte range = Wire.read();
  range &= ~(range_MASK);
  range |= 0x02 << 1 ;
  Wire.write(0x35);
  Wire.write(range);
  delay(20);
  /*Set interrupt latch state to non latching*/
  Wire.write(0x21);
  byte latch_int = Wire.read();
  latch_int &= ~(0x01);
  Wire.write(0x21);
  Wire.write(latch_int);
  delay(20);
  /*Set interrupt type to new data*/
  Wire.write(0x21);
  byte int_type = Wire.read();
  int_type |= 0x02;
  Wire.write(0x21);
  Wire.write(int_type);
  delay(20);
  return(0);
Third Code:
//BMA 180 demo, from: http://www.electrodragon.com/?p=3660
#include <Wire.h>
  Wire.begin();
  Wire.write(0x10);
  Wire.write(0xB6);
  delay(10);
  Wire.write(0x0D);
  Wire.write(0x10);
  Wire.write(0x20);
  data = Wire.read();
  Wire.write(0x35);
  unsigned int data = Wire.read();
  Serial.print(data);
  data = Wire.read();
  Serial.print(data);
  data = Wire.read();
  Serial.print(data);
  Serial.println();
The Question is, what the different of those code? Why they have different output value, and which is the most correct method to read data from BMA180?
Try all of them,  and see what they do.   You can scale the numbers however you like.
