Topic: XBee responding to previous character (Read 948 times) previous topic - next topic
nikki
This is kind of a follow on to a previous thread, but with different hardware and a bit more detail...
This time I'm using an XBee Series 2 Co-ordinator connected to my laptop via a XBee Explorer USB and the corresponding router is connected to a Real Bare Bones Board in turn connected to my laptop via USB.
RO/ Packetisation Timeout is set to 0
The sketch I'm running should echo back the number sent for 1-3 and 'misc' for everything else.
With the code below, I'm finding that when I send a digit the first one doesn't have an effect, and thereafter each digit sent triggers the appropriate response to the previous digit. Here's the output from the X-CTU terminal on the coordinator (red from the router, blue is what sending to the router)
.misc
.misc
.10
.0
.0
.21
.1
.32
.2
.2
.2
.4misc
.misc
.0misc
.misc
.misc
.10
.0
.111
.1
.221
.2
.32
.3misc
.misc
#include <SoftwareSerial.h> //includes the software serial library
#include <TinyGPS.h>  // includes the TinyGPS library
SoftwareSerial XbeeSerial(9, 10);
// a byte to receive data:
char inByte = 0;
int Xbeepower = 6;
  XbeeSerial.begin(9600);
  pinMode(Xbeepower, OUTPUT);
  digitalWrite(Xbeepower, HIGH);
} //end setup
  // get any incoming data from xbee:
  if (XbeeSerial.available() > 1) {
    // read a byte
    inByte = XbeeSerial.read();
  if (inByte == '0') {
    Serial.println("0");
    XbeeSerial.println("0");
  else if (inByte == '1') {
    Serial.println("1");
    XbeeSerial.println("1");
  else if (inByte == '2') {
    Serial.println("2");
    XbeeSerial.println("2");
  // do nothing if anything else was received
  else {
    Serial.println("misc");
    XbeeSerial.println("misc");
  delay(2000);
} //end loop
So, sending each digit twice kind of works as a workaround, but it would be good to understand what's causing this and, ideally, just send each digit once. (I'm hoping to build up to sending arrays.)
Am I sending the digits in the wrong format or something like that?
Thanks
Jack Christensen
I wouldn't think delay(2000) is necessary or desirable. Why is it there? What happens if it's removed?
nikki
It's there for you :)
(To bring the terminal output down to something manageable that conveyed what's going on - same spirit as stripping surplus stuff out of the code)
Without any delay it zips past too fast to see what's going on, but with a 200ms delay, the same behaviour can clearly be seen.
Jack Christensen
But isn't it only responding to what it's sent, and the data that's being sent is being typed into the X-CTU terminal?
nikki
I moved everything into the
statement and I think it's now doing what you think it's doing - just one response for every key pressed (the original code repeats the output until another key press)
Terminal output looks like this (I hit enter a few times at the start)
misc
.misc
.0misc
.10
.21
.32
.4misc
.5misc
.0misc
.10
.21
.32
.4misc
char inByte = 0;
int Xbeepower = 6;
} //end setup
    // read a byte
  else {
  delay(200);
} //end loop
Jack Christensen
Try changing
to
  if (XbeeSerial.available() > 0) {
Probably delay() can be totally removed, with the recent changes.
nikki
Brilliant! That seems to have done the trick! Thank you!
Jack Christensen
LOL, glad to help a bit. It would have been more brilliant had I seen it earlier! One of those obvious things that's easy to miss :D
