I have programmed an Arduino Leonardo with the following code:
#include <stdio.h>
#include <Wire.h>
#define RLY08_ADDRESS1 0x38
int i;
char command[3];
if (Serial1.available() > 0) {
for (i=0; i<2; i++){
command[i] = Serial1.read();
command[2] = '\0';
delay(100);
if (strcmp(command, "11") == 0){
Wire.beginTransmission(0x38);
Wire.write(0x00);
Wire.write(0x65);
Wire.endTransmission();
Wire.write(0x00);
Wire.write(0x6F);
The question is:
I receive, through serial communication, 2 bytes and if the bytes are "11" in unsigned char format the if condition
(strcmp(command, "11") == 0)is executed and it works fine but the execution of the instruction is one time only.
If I receive any bytes from serial communication, the if instruction
(strcmp(command, "11") == 0) is not executed more. Why? the char command[2] contain the "11" values always.
Regards,
Moderator edit: Italic tags swapped for CODE TAGS
