Topic: HC-SR04 analog pin ? (Read 8607 times) previous topic - next topic
Henrik_Markussen
Hi all
Just recieved a couple of HC-SR04 sensors.
I was wondering... Is it possible to run theese on the arduino uno anolog pins ?
Or does it have to be on the digital ?
All examples I can find on the net, they are connected to digital pins.
The problem/clue is, when using the L293 motor shield, the analog pins are all unused.
Best regards
Henrik
pylon
Yes. All the analog pins of a standard Arduino can be used a digital I/Os. Most Arduino pins have more than one functionality. For example the pin A4 have three usages: analog input, digital input/output and I2C SDA.
Henrik_Markussen
Brilliant. Thank you for the hint  :)
teckel
Also, you can use the NewPing library and control your sensor using only one pin instead of two.  This could also save you in a pinch.  It's also a VERY good idea to use the NewPing library if you're also using motors, as other ultrasonic libraries or code will give you grief as they don't multitask well (or at all) and cause long 1 second delays.
Tim
My hardware: Arduino, Teensy 2.0, Teensy 3.2 & custom ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My Projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
