Pages: [1]   Go Down
Author Topic: Interrupt + encoder + DUE  (Read 773 times)
Offline Offline
Newbie
View Profile
Hello,
I'm experiencing a strange behavior whit Arduino Due,
Running this simple code I'm returning the encoder with HALF RESOLUTION,
Code:
#define encoder0PinA  20
#define encoder0PinB  21
volatile long encoder0Pos = 0;
  pinMode(encoder0PinA, INPUT);
  pinMode(encoder0PinB, INPUT);
    attachInterrupt(20, doEncoderMotor0, CHANGE);
  attachInterrupt(21, doEncoderMotor1, CHANGE);
  Serial.begin (9600);
  Serial.println("start");                // a personal quirk
void loop(){
     Serial.println ( encoder0Pos );
void doEncoderMotor0(){
  if (digitalRead(encoder0PinA) == HIGH) {   // found a low-to-high on channel A
    if (digitalRead(encoder0PinB) == LOW) {  // check channel B to see which way
                                             // encoder is turning
      encoder0Pos = encoder0Pos - 1;         // CCW
    else {
      encoder0Pos = encoder0Pos + 1;         // CW
  else                                        // found a high-to-low on channel A
    else {
void doEncoderMotor1(){
  // look for a low-to-high on channel B
  if (digitalRead(encoder0PinB) == HIGH) {
    // check channel A to see which way encoder is turning
    if (digitalRead(encoder0PinA) == LOW) {
      encoder0Pos = encoder0Pos + 1;         // CCW
    else {
      encoder0Pos = encoder0Pos - 1;         // CW
  // Look for a high-to-low on channel B
  else {
    // check channel B to see which way encoder is turning
    else {
was fine with Arduino MEGA..
Any Theory? I'm getting mad...
Thank you
Luca
Logged
Bologna, Italy
Offline Offline
Newbie
View Profile
I had some troubles with the new Due and interrupts on several pins but this patch has saved me: http://arduino.cc/forum/index.php/topic,146430.0.html
Hope it helps! smiley-wink
Logged
Pages: [1]   Go Up
Jump to:
